CUBE integration Sipera Metaswitch Softswitch
Hello Friends,
I haven´t seen any ISR configuration about it and when I have got it, that is a little confuse.
This is my topology: UCM server>IP network>CUBE>SIP Trunk>ITSP
Is it necessary to set up the sip-server under sip-ua?
What type of ip address or network should i specify under ip trusted list?
What type of ip address or network should i specify under ip route?
What type of ip address should i specify under the dial-peers using Metaswitch, Sipera or softswitch?
Can I set up the same CUBE as MGCP on UCM?
Do you have any clear ISR example you can show?
0 Replies 0
