06-11-2013 01:41 AM - edited 03-16-2019 05:48 PM
Hello all
I have a cisco router 3925 , with 30 CUBE licenses . I have already received two license as white papers with a CD inlcude FL-CUBE-25 and FL-CUBE-5 whithout any PAK . How can i check the licenses are ok on my router?. Are these licenses come with the router , included with the oruter?.
06-11-2013 02:52 AM
Hello all
i need just a confirmation that there is no commands should be added to my router , the only confirmation that i bought the licenses the two papers which came with the router , is this true?.
06-11-2013 03:00 AM
CUBE Licenses are right to use licenses..SO they are just Paper licenses and no PAK comes with them
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
06-11-2013 03:44 AM
Thanks for your answer , so there any command should be done on the router.I need your help to start my configuration on CUBE router as a setup , because i did not activate the services on my CUCM cluster where i am still waiting the licenses .
voice service voip
allow-connections sip to sip
no supplementary-service sip moved-temporarily
no supplementary-service sip refer redirect ip2ip
sip
bind control source-interface GigabitEthernet0/1
bind media source-interface GigabitEthernet0/1
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g729r8
codec preference 4 g729br8
codec preference 5 g723ar53
dial-peer voice 1 voip
answer-address .T
incoming calles-number .T
dtmf-relay rtp-nte
voice-class codec 1
session protocol sipv2
dial-peer voice 2 voip
destination-pattern ....
session-target IPv4:X.X.X.X (IP of CUCM)
dtmf-relay rtp-nte
voice-class codec 1
dial-peer voice 3 voip
description SIPOutgoing Calls
destination-pattern .T
session target ipv4:x.x.x.x:5060 (ITSP IP)
voice-class codec 1
voice-class sip dtmf-relay force rtp-nte
dtmf-relay rtp-nte
no vad
sip-uaIs there any missing command , is it necessary to use MTP ?.
thanks
