CUBE outbound calls to flowroute not working
Signups
Hi, I'm trying to follow Flowroute's guide to setup a trunk for CUCM however I cannot get any outbound calls to work.
I do have a firewall on front of the CUBE but I have tested this is not the cause by using a SIP client to make a call from the same subnet as the CUBE and ive disabled the SIP and RTS ALG filters.
I can see from the dashboard that the CUBE is registered with Flowroute. When I do a test call using csim start I can see that both RTP and SIP packets going outbound just like when I make a call from x-lite to flowroute.
But all test calls to flowroute from the CUBE fail almost immediately, The dial peer is being matched and there is no other that could be taking over. Ive been onto flowroute and they cant see any calls being placed.
Debugging the sip call gives the following
csim start 12064330999
csim: called number = 12064330999, loop count = 1 ping count = 0
csim err csim Disconnected recvd DISC cid(24)
Nov  8 22:27:17.530: //24/CFEDB3BA807C/SIP/Error/is_sip_snr_call:
 CCSIP: invalid call entry
Nov  8 22:27:17.530: //24/CFEDB3BA807C/SIP/Error/sipSPIGetCallServerGroupTargets:
 No server group configured
Nov  8 22:27:17.530: //24/CFEDB3BA807C/SIP/Error/sipSPI_ipip_set_history_info_header:
 ccb->src_addr_str is NULL
Nov  8 22:27:17.530: //24/CFEDB3BA807C/SIP/Error/sipSPIOutgoingCallSDP:
 Could not cre
csim: loop = 1, failed = 1
csim: call attempted = 1, setup failed = 1, tone failed = 0
CUBE#ate source SDP for Outgoing Call
Nov  8 22:27:17.530: //24/CFEDB3BA807C/SIP/Error/sipSPICreateOutboundSDP:
 Error in creating an SDP for the outbound call - Check for supported codecs
Nov  8 22:27:17.530: //24/CFEDB3BA807C/SIP/Error/ccsipDoPostDNSAndENUMProcForInitialInvite:
 Error during deferred outbound SDP creation
Nov  8 22:27:17.530: //-1/xxxxxxxxxxxx/SIP/Error/sipSPIGetContentQSIG:
 No Inbound Container Created !!!
Nov  8 22:27:17.530: //-1/xxxxxxxxxxxx/SIP/Error/sipSPIGetContentQ931:
Nov  8 22:27:17.530: //-1/xxxxxxxxxxxx/SIP/Error/httpish_msg_free:
 Freeing NULL pointer!
Nov  8 22:27:17.530: //24/CFEDB3BA807C/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x0x22A32638
State of The Call        : STATE_DEAD
TCP Sockets Used         : NO
Calling Number           : 420696969
Called Number            : 12064330999
Source IP Address (Sig  ): 10.0.0.221
Destn SIP Req Addr:Port  : :5060
Destn SIP Resp Addr:Port : :5060
Destination Name         : sip.flowroute.com
The config is
version 15.4
hostname CUBE
boot-start-marker
boot-end-marker
aaa new-model
aaa authentication login local_access local
aaa session-id common
clock timezone GMT 0 0
ip name-server 10.0.0.11
ip name-server 10.0.0.12
ip name-server 10.0.0.13
ip name-server 10.0.0.14
ip cef
no ipv6 cef
cts logging verbose
crypto pki trustpoint TP-self-signed-2025240156
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-2025240156
 revocation-check none
 rsakeypair TP-self-signed-2025240156
crypto pki certificate chain TP-self-signed-2025240156
 certificate self-signed 01
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 32303235 32343031 3536301E 170D3137 31303236 32303438
  35335A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 30323532
  34303135 3630819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100B187 1E2A2B06 D1FC2095 9E73F82C 4BE76472 B77F6893 77871F10 B566C372
  EA5625D9 E55762E6 5845FB92 EA0A0843 C4C29FF8 791FFC74 159B70BF 7B176043
  1CBA43B2 C6593675 4D414184 42DF6EB6 93A82FF9 9A638D98 C6BA4C67 144B70C0
  F807EE72 D015EBD9 18A44433 C274CE35 68A9C3E1 E19D477B CA7DD1F6 E18D99E8
  B55D0203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
  551D2304 18301680 14C54A5F 8B8E4E43 ADFAF1D2 38FBC18A 9DB30895 B9301D06
  03551D0E 04160414 C54A5F8B 8E4E43AD FAF1D238 FBC18A9D B30895B9 300D0609
  2A864886 F70D0101 05050003 81810026 A5845B63 703D194E 3E6BA55B F7367A8F
  33310837 FF47CCC5 CDE50A55 24EBCE07 E07F86D0 575C3DC1 989339EE 897EC8F3
  F782A74C BA445301 E32839B6 9F946DFB 43F18618 9170081D 7FE3FA99 83D98C4C
  C5D87ED1 CDC84DA1 0F181003 CC46043B F7ACAEA4 8D2DC9D5 0E88DB02 C8CA34B8
  10B02020 B381512C 3CF8F685 B2D301
  	quit
voice-card 0
voice call send-alert
voice rtp send-recv
voice service voip
 no ip address trusted authenticate
 allow-connections sip to sip
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
 h323
 sip
  min-se 900 session-expires 900
  registrar server
voice class codec 1
 codec preference 1 g711ulaw
voice class h323 1
  h225 timeout tcp establish 3
voice translation-rule 5
 rule 1 /^9\(1[2-9]..[2-9]......\)$/ /\1/
 rule 2 /^9\([2-9]......\)$/ /1234\1/
 rule 5 /^\(.......\)$/ /1234\1/
voice translation-profile addlocal
 translate called 5
license udi pid CISCO2901/K9 sn FTX181781ZZ
license boot module c2900 technology-package securityk9
license boot module c2900 technology-package uck9
license boot module c2900 technology-package datak9
hw-module pvdm 0/0
redundancy
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 no ip address
 duplex auto
 speed auto
interface GigabitEthernet0/0.10
 encapsulation dot1Q 10
 ip address 10.0.0.221 255.255.255.0
 ip nbar protocol-discovery
 h323-gateway voip interface
 h323-gateway voip bind srcaddr 10.0.0.221
interface GigabitEthernet0/1
 no ip address
 shutdown
 duplex auto
 speed auto
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip route 0.0.0.0 0.0.0.0 10.0.0.20
control-plane
voice-port 0/0/0
 connection plar opx 100
 caller-id enable
voice-port 0/0/1
voice-port 0/0/2
voice-port 0/0/3
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
dial-peer voice 1 voip
 description *** Outgoing Flowroute ***
 translation-profile outgoing addlocal
 destination-pattern 1[2-9]..[2-9]......
 session protocol sipv2
 session target dns:sip.flowroute.com
 voice-class codec 1
 dtmf-relay rtp-nte
 no vad
sip-ua
 credentials username 88590685 password 7 1531215B0629333E7E1E622011 realm sip.flowroute.com
 authentication username 88590685 password 7 106D234E07140A115A297D2926 realm sip.flowroute.com
 calling-info pstn-to-sip from number set 420696969
 no remote-party-id
 retry invite 3
 retry bye 3
 retry cancel 3
 retry register 3
 registrar dns:sip.flowroute.com expires 600
 sip-server dns:sip.flowroute.com
gatekeeper
 shutdown
 vstack
line con 0
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport output lat pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 transport input none
scheduler allocate 20000 1000
ntp master
ntp server 0.pool.ntp.org source GigabitEthernet0/0.10
end
 Can anyone suggest what might be causing this ?
0 Replies 0
