CUBE Phone-Proxy on IRS4300 running 16.05.01b
jtwardowski
Greetings, wonder if anyone can help with IRS4300 running 16.05.01b version.
Trying to work out phone-proxy configuration for the "outside" phones being able to register to cucm.
CUCM running 11.5 (pub and sub), inside interface on 4300 L2 to CUCM.
I was following several docs, only all them are related to 15.x configs:
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/voice/cube_interop/configuration/15-mt/cube-interop-15-mt-book/voi-cucm-lineside.html#reference_956BE6CA0F3A43EB9D7E538ABE666177
https://ciscocollab.wordpress.com/2014/04/08/cube-sip-lineside-phone-vpn-configuration/
https://www.cisco.com/c/en/us/support/docs/unified-communications/unified-border-element/200213-Configure-and-Troubleshoot-CUBE-SIP-Line.html.
I'm still confused about certs that should be used....
Also, maybe anyone can point me to proxy config doc for ver 16.x?
One issue i run in to is related to CUCM pub. It's using name, not IP which was the issues with ver 15.x
I try to point flow to CUCM sub that is using IP as work around, not sure if that may play any role.
I would appreciate any assistance/help with getting this resolved.
At this point i come with the following configuration:
crypto pki trustpoint selfsign
 enrollment selfsigned
 subject-name CN=CUBE01 CN=IPONE
 revocation-check none
 rsakeypair selfsign
crypto pki trustpoint ccm1
 enrollment terminal
crypto pki trustpoint Cisco_Manufacturing_CA
 enrollment terminal
crypto pki trustpoint ccm11
 enrollment terminal
crypto pki trustpoint capf11
 enrollment terminal
crypto pki certificate chain selfsign
 certificate self-signed 01
  <ommited>
crypto pki certificate chain ccm1
 certificate ca 756449853083DC104B5F8CEA2DB31BAB
 <ommited>
crypto pki certificate chain Cisco_Manufacturing_CA
 certificate ca 6A6967B3000000000003
 <ommited>
crypto pki certificate chain ccm11
<ommited>
crypto pki certificate chain capf11
 certificate ca 79B0BD03DC22CBD5A85E26DC5FC8CFE1
 <ommited>
voice service voip
 no ip address trusted authenticate
 allow-connections sip to sip
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
 sip
  session transport tcp
  header-passing
  registrar server
  nat auto
  pass-thru headers unsupp
  pass-thru subscribe-notify-events all
  pass-thru content unsupp
  registration passthrough
  extension cucm
voice class uri 1 sip
 host ipv4:<pub_ip>
voice class uri 2 sip
 host ipv4:<local_ip>
voice class uri 3 sip
 host ipv4:<cucm_ip>
voice class sip-profiles 10
 request INVITE peer-header sip contact copy ">(;.*)" u01
 request REGISTER peer-header sip contact copy ">(;.*)" u02
 request INVITE sip-header Cisco-Guid remove
 request INVITE sip-header Contact modify "(.*)" "\1\u10"
 request REGISTER sip-header Contact modify "(.*)" "\1\u20"
voice class sip-profiles 11
 request INVITE peer-header sip SIP-Req-URI copy "sip:([^@]*)@" u02
 response 200 peer-header sip contact copy ">(;.*)" u03
 request CANCEL peer-header sip SIP-Req-URI copy "sip:([^@]*)@" u04
 request INVITE sip-header Contact modify "(.)*" "\1\u10"
 response 200 sip-header Contact modify "(.)*" "\1\u30"
 request CANCEL sip-header SIP-Req-URI modify ".*" "INVITE sip:\u0<pub_ip> SIP/2.0"
 response 200 sip-header Contact modify "(.*)" "\1\u30"
 request CANCEL sip-header SIP-Req-URI modify "*." "CANCEL sip:\u04<cucm-ip> SIP/2.0"
voice class sip-hdr-passthrulist 10
 passthru-hdr Remote-Pary-ID
 passthru-hdr Call-Info
 passthru-hdr Content-ID
 passthru-hdr supported
 passthru-hdr require
 passthru-hdr Referred-By
voice class sip-copylist 10
 sip-header contact
voice class sip-copylist 11
 sip-header contact
interface GigabitEthernet0/0/0
 ip address <pub_ip>
 speed 10
 no negotiation auto
interface GigabitEthernet0/0/1
 ip address <local_ip>
 negotiation auto
dspfarm profile 1 transcode universal
 associate application CUBE
 shutdown
voice-ctl-file ctl_secure
 record-entry selfsigned trustpoint selfsign
 record-entry cucm-tftp trustpoint ccm11
 record-entry capf trustpoint capf11
 complete
voice-phone-proxy cube01
 tftp-server address ipv4 <cucm_ip> local-addr ipv4 <local_ip> acc-addr ipv4 <pub_ip>
 ctl-file ctl_secure
 access-secure
 service-map server-addr ipv4 <cucm_ip> port 8443 acc-addr ipv4 209.29.5.21 port 8443
 service-map server-addr ipv4 <cucm_ip> port 8080 acc-addr ipv4 209.29.5.21 port 8080
 service-map server-addr ipv4 <cucm_ip> port 3804 acc-addr ipv4 209.29.5.21 port 3804
 complete
voice-phone-proxy tftp-address ipv4 <local_ip>
 port-range 30000 60000
voice-phone-proxy tftp-address ipv4 <pub_ip>
voice-phone-proxy file-buffer size 60
dial-peer voice 2 voip
 description DP_facing_CCM
 session protocol sipv2
 session target ipv4:<cucm_ip>
 destination uri 1
 incoming uri via 3
 voice-class sip extension cucm
 voice-class sip call-route url
 voice-class sip profiles 11
 voice-class sip pass-thru headers 10
 voice-class sip copy-list 11
 dtmf-relay rtp-nte
 codec transparent
dial-peer voice 1 voip
 phone-proxy cube01 signal-addr ipv4 <pub_ip> cucm ipv4 <cucm_ip>
 description *** Dialpeer Facing Outside ***
 session target registrar
 destination uri 2
 incoming uri request 1
 voice-class sip profiles 10
 voice-class sip registration passthrough registrar-index 1
 voice-class sip copy-list 10
 dtmf-relay rtp-nte
 codec transparent
sip-ua
 timers connection aging 60
 registrar 1 ipv4:<cucm_ip> expires 3600 refresh-ratio 100 tcp
Phones are not able to register, phone-proxy debug shows the following:
*Sep 18 15:08:41.208: Phone proxy new phone event handler 1
*Sep 18 15:08:41.208: Phone proxy: TCP Socket accept
*Sep 18 15:08:41.208: Create device hash table for phone <phone_ip> : 49642
*Sep 18 15:08:41.208: TCP access socket inherit fd:0 from fd:5
*Sep 18 15:08:41.208: pp_add_tcp_access_socket session 0x7F7220283A60 access side raddr:<phone_ip>, socket:0
*Sep 18 15:08:41.210: PP: pp_sock_tcp_read_handler sock:0 session:7F7220283A60
*Sep 18 15:08:41.210: access socket recv http:GET /SEP247E12BFD0CD.cnf.xml.sgn HTTP/1.1
Host:<pub_ip>:6970
*Sep 18 15:08:41.210: PP: Remote phone from <phone_ip>/49642 requesting GET /SEP247E12BFD0CD.cnf.xml.sgn HTTP/1.1
Host:<pub_ip>:6970
 at <pub_ip>/6970
*Sep 18 15:08:41.210: get file name:SEP247E12BFD0CD.cnf.xml.sgn
*Sep 18 15:08:41.210: core side ip  <cucm_ip> session 0x7F7220283A60
*Sep 18 15:08:41.211: PP socket connect 1 remote addr <cucm_ip> port 6970
*Sep 18 15:08:41.211: PP socket connect 1 remote addr <cucm_ip> port 6970 in progress
*Sep 18 15:08:41.211: pp_add_tcp_core_socket session 0x7F7220283A60 core side raddr:<cucm_ip>, socket:1
*Sep 18 15:08:41.211: PP: The remote phone is requesting file SEP247E12BFD0CD.cnf.xml.sgn.
PP: Removing .sgn extension, SBC is requesting file SEP247E12BFD0CD.cnf.xml.sgn from Call Manager HTTP server.
*Sep 18 15:08:41.211: PP: SBC sent request for SEP247E12BFD0CD.cnf.xml.sgn sourced from 10.26.200.30:40047 to <cucm_ip>:6970, vrf Global
*Sep 18 15:08:41.211: PP: modify http host, header:GET /SEP247E12BFD0CD.cnf.xml HTTP/1.1
Host:<cucm_ip>:6970
, size: 65
*Sep 18 15:08:41.211: Phoneproxy tried to send data 0x7F72202D7340 65 bytes, socket 1 sent nothing,tcp connect not finished
*Sep 18 15:08:41.212: Got socket write event to resend on socket fd 1 resend queue:0x7F721D1FE410
*Sep 18 15:08:41.212: PP: pp_sock_tcp_read_handler sock:1 session:7F7220283A60
*Sep 18 15:08:41.219: PP: pp_sock_tcp_read_handler sock:1 session:7F7220283A60
*Sep 18 15:08:41.219: http core side first pkg
*Sep 18 15:08:41.219: http 200OK msg size:12997process http core side didn't finish,will continue process
*Sep 18 15:08:41.220: PP: pp_sock_tcp_read_handler sock:1 session:7F7220283A60process http core side didn't finish,will continue process
*Sep 18 15:08:41.221: PP: pp_sock_tcp_read_handler sock:1 session:7F7220283A60process http core side didn't finish,will continue process
*Sep 18 15:08:41.222: PP: pp_sock_tcp_read_handler sock:1 session:7F7220283A60process http core side didn't finish,will continue process
*Sep 18 15:08:41.223: PP: pp_sock_tcp_read_handler sock:1 session:7F7220283A60
*Sep 18 15:08:41.223: PP: Complete configuration file received from Call Manager TFTP server, beginning config file modification process.
*Sep 18 15:08:41.223: PP: Config Modify: rewriting addr to <cucm_ip>
*Sep 18 15:08:41.223: PP: Config Modify: rewriting addr to 0.0.0.0
*Sep 18 15:08:41.223: PP: CM Name Config Modify : detected Call Manager Name.
*Sep 18 15:08:41.223: PP: Config Modify: rewriting addr to <pub_ip>
*Sep 18 15:08:41.223: PP: Config Modify: rewriting port 5060 to 5060
*Sep 18 15:08:41.223: PP: Config Modify: rewriting port 5061 to 5061
*Sep 18 15:08:41.224: PP: Config Modify: rewriting addr to <pub_ip>
*Sep 18 15:08:41.224: PP: CM Config Modify : detected Call Manager Node Name.
*Sep 18 15:08:41.224: PP: Config Modify: rewriting addr to <cucm_ip>
*Sep 18 15:08:41.224: PP: Config Modify: rewriting addr to 0.0.0.0
*Sep 18 15:08:41.224: PP: CM Name Config Modify : detected Call Manager Name.
*Sep 18 15:08:41.224: PP: Config Modify: rewriting port 5060 to 5060
*Sep 18 15:08:41.224: PP: Config Modify: rewriting port 5061 to 5061
*Sep 18 15:08:41.224: PP: Config Modify : detected Call Manager Node Name.
*Sep 18 15:08:41.224: PP: Config Modify : deviceSecurityMode set to 1 (unencrypted), modifying deviceSecurityMode to 3 (encrypted).
*Sep 18 15:08:41.224: PP: Url ipaddr invalid ip addr
*Sep 18 15:08:41.225: PP: Url ipaddr invalid ip addr
*Sep 18 15:08:41.225: PP: Config Modify : Modifying to TLS as the transport layer protocol.
*Sep 18 15:08:41.225: PP: Config Modify: rewriting addr to 0.0.0.0
*Sep 18 15:08:41.225: PP:CAPF Config Modify : detected Call Manager Node Name. Enter ctl_sign
PP: Encrypting and signing modified config file using trustpoint <selfsign>.
ctl_sign: total_file_len=13323, signature_len = 128
*Sep 18 15:08:41.230: PP: Data sent from <pub_ip>/6970 to remote phone at <phone_ip>/49642
process http core side succ,delete socket
*Sep 18 15:08:41.231: PP delete session:0x7F7220283A60, core:0, access:1
*Sep 18 15:08:41.251: Got socket write event to resend on socket fd 0 resend queue:0x7F721D1FE4F0
*Sep 18 15:08:41.253: Got socket write event to resend on socket fd 0 resend queue:0x7F721D1FE4F0
*Sep 18 15:08:41.270: Got socket write event to resend on socket fd 0 resend queue:0x7F721D1FE4F0
*Sep 18 15:08:41.275: Got socket write event to resend on socket fd 0 resend queue:0x7F721D1FE4F0
*Sep 18 15:08:41.276: Got socket write event to resend on socket fd 0 resend queue:0x7F721D1FE4F0
*Sep 18 15:08:41.291: Got socket write event to resend on socket fd 0 resend queue:0x7F721D1FE4F0
*Sep 18 15:08:41.297: Got socket write event to resend on socket fd 0 resend queue:0x7F721D1FE4F0
*Sep 18 15:08:41.299: Got socket write event to resend on socket fd 0 resend queue:0x7F721D1FE4F0
*Sep 18 15:08:41.301: Got socket write event to resend on socket fd 0 resend queue:0x7F721D1FE4F0
*Sep 18 15:08:41.313: Got socket write event to resend on socket fd 0 resend queue:0x7F721D1FE4F0
*Sep 18 15:08:41.319: Got socket write event to resend on socket fd 0 resend queue:0x7F721D1FE4F0
*Sep 18 15:08:41.321: Got socket write event to resend on socket fd 0 resend queue:0x7F721D1FE4F0
*Sep 18 15:08:41.323: Got socket write event to resend on socket fd 0 resend queue:0x7F721D1FE4F0
*Sep 18 15:08:41.325: Got socket write event to resend on socket fd 0 resend queue:0x7F721D1FE4F0
*Sep 18 15:08:41.327: Got socket write event to resend on socket fd 0 resend queue:0x7F721D1FE4F0
*Sep 18 15:08:41.380: PP: pp_sock_tcp_read_handler sock:0 session:7F7220283A60
*Sep 18 15:08:41.380: PP delete session:0x7F7220283A60, core:0, access:0
*Sep 18 15:08:41.380: Remove device hash table for phone <phone_ip> : 49642
*Sep 18 15:08:43.911: Phoneproxy_mgt_process, unknown event.
*Sep 18 15:08:43.930: Phoneproxy_mgt_process, unknown event.
*Sep 18 15:08:43.930: Phone proxy new phone event handler 1
*Sep 18 15:08:43.930: Phone proxy: TCP Socket accept
*Sep 18 15:08:43.930: Create device hash table for phone <phone_ip> : 49643
*Sep 18 15:08:43.930: TCP access socket inherit fd:0 from fd:5
*Sep 18 15:08:43.930: pp_add_tcp_access_socket session 0x7F7220283A60 access side raddr:<phone_ip>, socket:0
*Sep 18 15:08:43.932: PP: pp_sock_tcp_read_handler sock:0 session:7F7220283A60
*Sep 18 15:08:43.932: access socket recv http:GET /Canada/g3-tones.xml.sgn HTTP/1.1
Host:<pub_ip>:6970
*Sep 18 15:08:43.932: PP: Remote phone from <phone_ip>/49643 requesting GET /Canada/g3-tones.xml.sgn HTTP/1.1
Host:<pub_ip>:6970
 at <pub_ip>/6970
*Sep 18 15:08:43.932: get file name:Canada/g3-tones.xml.sgn
*Sep 18 15:08:43.932: DBG: check if filename(Canada/g3-tones.xml.sgn) buffered
*Sep 18 15:08:43.932: core side ip  <cucm_ip> session 0x7F7220283A60
*Sep 18 15:08:43.932: PP socket connect 1 remote addr <cucm_ip> port 6970
*Sep 18 15:08:43.933: PP socket connect 1 remote addr <cucm_ip> port 6970 in progress
*Sep 18 15:08:43.933: pp_add_tcp_core_socket session 0x7F7220283A60 core side raddr:<cucm_ip>, socket:1
*Sep 18 15:08:43.933: PP: SBC sent request for Canada/g3-tones.xml.sgn sourced from 10.26.200.30:40048 to <cucm_ip>:6970, vrf Global
*Sep 18 15:08:43.933: PP: modify http host, header:GET /Canada/g3-tones.xml.sgn HTTP/1.1
Host:<cucm_ip>:6970
, size: 65
*Sep 18 15:08:43.933: Phoneproxy tried to send data 0x7F72202D7340 65 bytes, socket 1 sent nothing,tcp connect not finished
*Sep 18 15:08:43.933: Got socket write event to resend on socket fd 1 resend queue:0x7F721D1FE410
*Sep 18 15:08:43.934: PP: pp_sock_tcp_read_handler sock:1 session:7F7220283A60
*Sep 18 15:08:43.935: PP: pp_sock_tcp_read_handler sock:1 session:7F7220283A60
*Sep 18 15:08:43.935: http core side first pkg
*Sep 18 15:08:43.935: http error msg
*Sep 18 15:08:43.935: PP: Data sent from <pub_ip>/6970 to remote phone at <phone_ip>/49643
*Sep 18 15:08:43.935: PP delete session:0x7F7220283A60, core:0, access:1
*Sep 18 15:08:43.956: PP: pp_sock_tcp_read_handler sock:0 session:7F7220283A60
*Sep 18 15:08:43.956: PP delete session:0x7F7220283A60, core:0, access:0
*Sep 18 15:08:43.956: Remove device hash table for phone <phone_ip> : 49643
*Sep 18 15:08:44.337: Phoneproxy_mgt_process, unknown event.
*Sep 18 15:08:44.356: Phoneproxy_mgt_process, unknown event.
*Sep 18 15:08:44.356: Phone proxy new phone event handler 1
*Sep 18 15:08:44.356: Phone proxy: TCP Socket accept
*Sep 18 15:08:44.356: Create device hash table for phone <phone_ip> : 49644
*Sep 18 15:08:44.356: TCP access socket inherit fd:0 from fd:5
*Sep 18 15:08:44.356: pp_add_tcp_access_socket session 0x7F7220283A60 access side raddr:<phone_ip>, socket:0
*Sep 18 15:08:44.357: PP: pp_sock_tcp_read_handler sock:0 session:7F7220283A60
*Sep 18 15:08:44.358: access socket recv http:GET /AppDialRules.xml HTTP/1.1
Host:<pub_ip>:6970
*Sep 18 15:08:44.358: PP: Remote phone from <phone_ip>/49644 requesting GET /AppDialRules.xml HTTP/1.1
Host:<pub_ip>:6970
 at <pub_ip>/6970
*Sep 18 15:08:44.358: get file name:AppDialRules.xml
*Sep 18 15:08:44.358: DBG: check if filename(AppDialRules.xml) buffered
*Sep 18 15:08:44.358: DBG: filename(AppDialRules.xml) has been buffered
*Sep 18 15:08:44.358: DBG: register filename(AppDialRules.xml) event(2) session(0x7F7220283A60) callback
*Sep 18 15:08:44.358: DBG: register filename(AppDialRules.xml) event(1) session(0x7F7220283A60) callback
*Sep 18 15:08:44.358: PP: Data sent from <pub_ip>/6970 to remote phone at <phone_ip>/49644
*Sep 18 15:08:44.397: PP: pp_sock_tcp_read_handler sock:0 session:7F7220283A60
*Sep 18 15:08:44.397: PP delete session:0x7F7220283A60, core:0, access:0
*Sep 18 15:08:44.397: DBG: unregister filename(AppDialRules.xml) event(3) session(0x7F7220283A60) callback
*Sep 18 15:08:44.397: Remove device hash table for phone <phone_ip> : 49644
*Sep 18 15:08:44.505: Phoneproxy_mgt_process, unknown event.
*Sep 18 15:08:44.524: Phoneproxy_mgt_process, unknown event.
*Sep 18 15:08:44.524: Phone proxy new phone event handler 1
*Sep 18 15:08:44.524: Phone proxy: TCP Socket accept
*Sep 18 15:08:44.524: Create device hash table for phone <phone_ip> : 49645
*Sep 18 15:08:44.524: TCP access socket inherit fd:0 from fd:5
*Sep 18 15:08:44.524: pp_add_tcp_access_socket session 0x7F7220283A60 access side raddr:<phone_ip>, socket:0
*Sep 18 15:08:44.526: PP: pp_sock_tcp_read_handler sock:0 session:7F7220283A60
*Sep 18 15:08:44.526: access socket recv http:GET /SK72f64050-7ad5-4b47-9bfa-5e9ad9cd4aa9.xml.sgn HTTP/1.1
Host:<pub_ip>:6970
*Sep 18 15:08:44.526: PP: Remote phone from <phone_ip>/49645 requesting GET /SK72f64050-7ad5-4b47-9bfa-5e9ad9cd4aa9.xml.sgn HTTP/1.1
Host:<pub_ip>:6970
 at <pub_ip>/6970
*Sep 18 15:08:44.526: get file name:SK72f64050-7ad5-4b47-9bfa-5e9ad9cd4aa9.xml.sgn
*Sep 18 15:08:44.527: DBG: check if filename(SK72f64050-7ad5-4b47-9bfa-5e9ad9cd4aa9.xml.sgn) buffered
*Sep 18 15:08:44.527: DBG: filename(SK72f64050-7ad5-4b47-9bfa-5e9ad9cd4aa9.xml.sgn) has been buffered
*Sep 18 15:08:44.527: DBG: register filename(SK72f64050-7ad5-4b47-9bfa-5e9ad9cd4aa9.xml.sgn) event(2) session(0x7F7220283A60) callback
*Sep 18 15:08:44.527: DBG: register filename(SK72f64050-7ad5-4b47-9bfa-5e9ad9cd4aa9.xml.sgn) event(1) session(0x7F7220283A60) callback
*Sep 18 15:08:44.527: PP: Data sent from <pub_ip>/6970 to remote phone at <phone_ip>/49645
*Sep 18 15:08:44.546: Got socket write event to resend on socket fd 0 resend queue:0x7F721D1FE4F0
*Sep 18 15:08:44.549: Got socket write event to resend on socket fd 0 resend queue:0x7F721D1FE4F0
*Sep 18 15:08:44.566: Got socket write event to resend on socket fd 0 resend queue:0x7F721D1FE4F0
*Sep 18 15:08:44.571: Got socket write event to resend on socket fd 0 resend queue:0x7F721D1FE4F0
*Sep 18 15:08:44.572: Got socket write event to resend on socket fd 0 resend queue:0x7F721D1FE4F0
*Sep 18 15:08:44.587: Got socket write event to resend on socket fd 0 resend queue:0x7F721D1FE4F0
*Sep 18 15:08:44.594: Got socket write event to resend on socket fd 0 resend queue:0x7F721D1FE4F0
*Sep 18 15:08:44.639: PP: pp_sock_tcp_read_handler sock:0 session:7F7220283A60
*Sep 18 15:08:44.639: PP delete session:0x7F7220283A60, core:0, access:0
*Sep 18 15:08:44.639: DBG: unregister filename(SK72f64050-7ad5-4b47-9bfa-5e9ad9cd4aa9.xml.sgn) event(3) session(0x7F7220283A60) callback
*Sep 18 15:08:44.639: Remove device hash table for phone <phone_ip> : 49645
*Sep 18 15:09:06.160: pp: file buffer manager 7F7213E16590 aging timer expired
*Sep 18 15:09:06.160: DBG: file buffer aging timeout, buffer total_size(14763), file_num(3)
*Sep 18 15:09:06.161: DBG: current hash elem num 3
*Sep 18 15:09:06.161: DBG: restart file buffer aging timer
5 Replies 5
R0g22
Didn't go through the logs but I will point out a couple of things -
1. Phone Proxy only supports 1024 bit encryption.
2. Ensure you don't have a SIP trunk on CUCM pointing to the CORE IP of CUBE. Registrations will be rejected.
Additionally, there are concerns regarding your phone proxy config. I am highlighting them below -
ctl-file ctl_secure
access-secure
complete
<local_ip> needs to be replaced with a CUBE core IP
<pub_ip> needs to be replaced with the CUBE access IP
acc-addr ipv4 209.29.5.21 >> this needs to be CUBE access IP
These changes need to be made throughout the config including dial-peers and sip uri.
In case you are wondering what the CORE and ACCESS ip addresses need to be -
CORE IP is the internal CUBE address used to connect to CUCM
ACCESS IP is for the interface that the remote phones will connect to.
it looks like my IP cleanup didn't work:-(
Anyhow, IPs are set as required.
In regards to 1024bit, that was clearly stated in one of the documents and i followed up with proper selfsigned 1024 cert.
209.29.5.21 is cube public (test)
<local_ip> is 10.26.200.30 = core ip
<cucm_ip> is 10.26.200.10 (pub)
The logs that you collected were with the correct config or corrected the confiig after reading my post ?
logs were collected with proper configuration. I just replaced IPs with genetic <device_ip> for the posting purpose.
For clarification i added IPs since removing/replacing them created some confusion.
Here is log in original version:
Sep 18 15:39:38.113: Phone proxy new phone event handler 1
*Sep 18 15:39:38.113: Phone proxy: TCP Socket accept
*Sep 18 15:39:38.113: Create device hash table for phone 69.156.48.65 : 49712
*Sep 18 15:39:38.113: TCP access socket inherit fd:0 from fd:5
*Sep 18 15:39:38.113: pp_add_tcp_access_socket session 0x7F7220283A60 access side raddr:69.156.48.65, socket:0
*Sep 18 15:39:38.114: PP: pp_sock_tcp_read_handler sock:0 session:7F7220283A60
*Sep 18 15:39:38.114: access socket recv http:GET /CTLSEP247E12BFD0CD.tlv HTTP/1.1
Host:209.29.5.21:6970
*Sep 18 15:39:38.114: PP: Remote phone from 69.156.48.65/49712 requesting GET /CTLSEP247E12BFD0CD.tlv HTTP/1.1
at 209.29.5.21/6970
*Sep 18 15:39:38.114: get file name:CTLSEP247E12BFD0CD.tlv
*Sep 18 15:39:38.114: this is ctl file
*Sep 18 15:39:38.115: PP: send http ctl file
*Sep 18 15:39:38.137: Got socket write event to resend on socket fd 0 resend queue:0x7F721D1FE410
*Sep 18 15:39:38.159: Got socket write event to resend on socket fd 0 resend queue:0x7F721D1FE410
*Sep 18 15:39:38.161: Got socket write event to resend on socket fd 0 resend queue:0x7F721D1FE410
*Sep 18 15:39:38.182: Got socket write event to resend on socket fd 0 resend queue:0x7F721D1FE410
*Sep 18 15:39:38.184: Got socket write event to resend on socket fd 0 resend queue:0x7F721D1FE410
*Sep 18 15:39:38.186: Got socket write event to resend on socket fd 0 resend queue:0x7F721D1FE410
*Sep 18 15:39:38.231: PP: pp_sock_tcp_read_handler sock:0 session:7F7220283A60
*Sep 18 15:39:38.232: PP delete session:0x7F7220283A60, core:0, access:0
*Sep 18 15:39:38.374: Phoneproxy_mgt_process, unknown event.
*Sep 18 15:39:38.392: Phoneproxy_mgt_process, unknown event.
*Sep 18 15:39:38.392: Phone proxy new phone event handler 1
*Sep 18 15:39:38.392: Phone proxy: TCP Socket accept
*Sep 18 15:39:38.393: Create device hash table for phone 69.156.48.65 : 49713
*Sep 18 15:39:38.393: TCP access socket inherit fd:0 from fd:5
*Sep 18 15:39:38.393: pp_add_tcp_access_socket session 0x7F7220283A60 access side raddr:69.156.48.65, socket:0
*Sep 18 15:39:38.394: PP: pp_sock_tcp_read_handler sock:0 session:7F7220283A60
*Sep 18 15:39:38.394: access socket recv http:GET /ITLSEP247E12BFD0CD.tlv HTTP/1.1
*Sep 18 15:39:38.395: PP: Remote phone from 69.156.48.65/49713 requesting GET /ITLSEP247E12BFD0CD.tlv HTTP/1.1
at 209.29.5.21/6970
*Sep 18 15:39:38.395: get file name:ITLSEP247E12BFD0CD.tlv
*Sep 18 15:39:38.395: DBG: check if filename(ITLSEP247E12BFD0CD.tlv) buffered
*Sep 18 15:39:38.395: DBG: filename(ITLSEP247E12BFD0CD.tlv) has been buffered
*Sep 18 15:39:38.395: DBG: register filename(ITLSEP247E12BFD0CD.tlv) event(2) session(0x7F7220283A60) callback
*Sep 18 15:39:38.395: DBG: register filename(ITLSEP247E12BFD0CD.tlv) event(1) session(0x7F7220283A60) callback
*Sep 18 15:39:38.395: PP: Data sent from 209.29.5.21/6970 to remote phone at 69.156.48.65/49713
*Sep 18 15:39:38.413: Got socket write event to resend on socket fd 0 resend queue:0x7F721D1FE410
*Sep 18 15:39:38.416: Got socket write event to resend on socket fd 0 resend queue:0x7F721D1FE410
*Sep 18 15:39:38.433: Got socket write event to resend on socket fd 0 resend queue:0x7F721D1FE410
*Sep 18 15:39:38.438: Got socket write event to resend on socket fd 0 resend queue:0x7F721D1FE410
*Sep 18 15:39:38.440: Got socket write event to resend on socket fd 0 resend queue:0x7F721D1FE410
*Sep 18 15:39:38.454: Got socket write event to resend on socket fd 0 resend queue:0x7F721D1FE410
*Sep 18 15:39:38.460: Got socket write event to resend on socket fd 0 resend queue:0x7F721D1FE410
*Sep 18 15:39:38.463: Got socket write event to resend on socket fd 0 resend queue:0x7F721D1FE410
*Sep 18 15:39:38.465: Got socket write event to resend on socket fd 0 resend queue:0x7F721D1FE410
*Sep 18 15:39:38.477: Got socket write event to resend on socket fd 0 resend queue:0x7F721D1FE410
*Sep 18 15:39:38.483: Got socket write event to resend on socket fd 0 resend queue:0x7F721D1FE410
*Sep 18 15:39:38.485: Got socket write event to resend on socket fd 0 resend queue:0x7F721D1FE410
*Sep 18 15:39:38.530: PP: pp_sock_tcp_read_handler sock:0 session:7F7220283A60
*Sep 18 15:39:38.530: PP delete session:0x7F7220283A60, core:0, access:0
*Sep 18 15:39:38.530: DBG: unregister filename(ITLSEP247E12BFD0CD.tlv) event(3) session(0x7F7220283A60) callback
*Sep 18 15:39:38.530: Remove device hash table for phone 69.156.48.65 : 49713
*Sep 18 15:39:39.536: Phoneproxy_mgt_process, unknown event.
*Sep 18 15:39:39.554: Phoneproxy_mgt_process, unknown event.
*Sep 18 15:39:39.554: Phone proxy new phone event handler 1
*Sep 18 15:39:39.554: Phone proxy: TCP Socket accept
*Sep 18 15:39:39.555: Create device hash table for phone 69.156.48.65 : 49714
*Sep 18 15:39:39.555: TCP access socket inherit fd:0 from fd:5
*Sep 18 15:39:39.555: pp_add_tcp_access_socket session 0x7F7220283A60 access side raddr:69.156.48.65, socket:0
*Sep 18 15:39:39.557: PP: pp_sock_tcp_read_handler sock:0 session:7F7220283A60
*Sep 18 15:39:39.557: access socket recv http:GET /SEP247E12BFD0CD.cnf.xml.sgn HTTP/1.1
*Sep 18 15:39:39.557: PP: Remote phone from 69.156.48.65/49714 requesting GET /SEP247E12BFD0CD.cnf.xml.sgn HTTP/1.1
at 209.29.5.21/6970
*Sep 18 15:39:39.557: get file name:SEP247E12BFD0CD.cnf.xml.sgn
*Sep 18 15:39:39.557: core side ip 10.26.200.11 session 0x7F7220283A60
*Sep 18 15:39:39.557: PP socket connect 1 remote addr 10.26.200.11 port 6970
*Sep 18 15:39:39.557: PP socket connect 1 remote addr 10.26.200.11 port 6970 in progress
*Sep 18 15:39:39.557: pp_add_tcp_core_socket session 0x7F7220283A60 core side raddr:10.26.200.11, socket:1
*Sep 18 15:39:39.557: PP: The remote phone is requesting file SEP247E12BFD0CD.cnf.xml.sgn.
*Sep 18 15:39:39.557: PP: SBC sent request for SEP247E12BFD0CD.cnf.xml.sgn sourced from 10.26.200.30:40071 to 10.26.200.11:6970, vrf Global
*Sep 18 15:39:39.558: PP: modify http host, header:GET /SEP247E12BFD0CD.cnf.xml HTTP/1.1
Host:10.26.200.11:6970
, size: 65
*Sep 18 15:39:39.558: Phoneproxy tried to send data 0x7F72202D7340 65 bytes, socket 1 sent nothing,tcp connect not finished
*Sep 18 15:39:39.558: Got socket write event to resend on socket fd 1 resend queue:0x7F721D1FE4F0
*Sep 18 15:39:39.558: PP: pp_sock_tcp_read_handler sock:1 session:7F7220283A60
*Sep 18 15:39:39.563: PP: pp_sock_tcp_read_handler sock:1 session:7F7220283A60
*Sep 18 15:39:39.563: http core side first pkg
*Sep 18 15:39:39.564: http 200OK msg size:12997process http core side didn't finish,will continue process
*Sep 18 15:39:39.564: PP: pp_sock_tcp_read_handler sock:1 session:7F7220283A60process http core side didn't finish,will continue process
*Sep 18 15:39:39.565: PP: pp_sock_tcp_read_handler sock:1 session:7F7220283A60process http core side didn't finish,will continue process
*Sep 18 15:39:39.566: PP: pp_sock_tcp_read_handler sock:1 session:7F7220283A60process http core side didn't finish,will continue process
*Sep 18 15:39:39.567: PP: pp_sock_tcp_read_handler sock:1 session:7F7220283A60
*Sep 18 15:39:39.567: PP: Complete configuration file received from Call Manager TFTP server, beginning config file modification process.
*Sep 18 15:39:39.567: PP: Config Modify: rewriting addr to 10.26.200.11
*Sep 18 15:39:39.567: PP: Config Modify: rewriting addr to 0.0.0.0
*Sep 18 15:39:39.568: PP: CM Name Config Modify : detected Call Manager Name.
*Sep 18 15:39:39.568: PP: Config Modify: rewriting addr to 10.26.200.11
*Sep 18 15:39:39.568: PP: Config Modify: rewriting addr to 209.29.5.21
*Sep 18 15:39:39.568: PP: Config Modify: rewriting port 5060 to 5060
*Sep 18 15:39:39.568: PP: Config Modify: rewriting port 5061 to 5061
*Sep 18 15:39:39.568: PP: CM Config Modify : detected Call Manager Node Name.
*Sep 18 15:39:39.568: PP: Config Modify: rewriting addr to 0.0.0.0
*Sep 18 15:39:39.568: PP: Config Modify : detected Call Manager Node Name.
*Sep 18 15:39:39.569: PP: Config Modify : deviceSecurityMode set to 1 (unencrypted), modifying deviceSecurityMode to 3 (encrypted).
*Sep 18 15:39:39.569: PP: Url ipaddr invalid ip addr
*Sep 18 15:39:39.569: PP: Config Modify : Modifying to TLS as the transport layer protocol.
*Sep 18 15:39:39.569: PP: Config Modify: rewriting addr to 0.0.0.0
*Sep 18 15:39:39.569: PP:CAPF Config Modify : detected Call Manager Node Name. Enter ctl_sign
*Sep 18 15:39:39.575: PP: Data sent from 209.29.5.21/6970 to remote phone at 69.156.48.65/49714
*Sep 18 15:39:39.575: PP delete session:0x7F7220283A60, core:0, access:1
*Sep 18 15:39:39.595: Got socket write event to resend on socket fd 0 resend queue:0x7F721D1FE410
*Sep 18 15:39:39.597: Got socket write event to resend on socket fd 0 resend queue:0x7F721D1FE410
*Sep 18 15:39:39.615: Got socket write event to resend on socket fd 0 resend queue:0x7F721D1FE410
*Sep 18 15:39:39.619: Got socket write event to resend on socket fd 0 resend queue:0x7F721D1FE410
*Sep 18 15:39:39.621: Got socket write event to resend on socket fd 0 resend queue:0x7F721D1FE410
*Sep 18 15:39:39.636: Got socket write event to resend on socket fd 0 resend queue:0x7F721D1FE410
*Sep 18 15:39:39.642: Got socket write event to resend on socket fd 0 resend queue:0x7F721D1FE410
*Sep 18 15:39:39.644: Got socket write event to resend on socket fd 0 resend queue:0x7F721D1FE410
*Sep 18 15:39:39.646: Got socket write event to resend on socket fd 0 resend queue:0x7F721D1FE410
*Sep 18 15:39:39.658: Got socket write event to resend on socket fd 0 resend queue:0x7F721D1FE410
*Sep 18 15:39:39.664: Got socket write event to resend on socket fd 0 resend queue:0x7F721D1FE410
*Sep 18 15:39:39.666: Got socket write event to resend on socket fd 0 resend queue:0x7F721D1FE410
*Sep 18 15:39:39.668: Got socket write event to resend on socket fd 0 resend queue:0x7F721D1FE410
*Sep 18 15:39:39.670: Got socket write event to resend on socket fd 0 resend queue:0x7F721D1FE410
*Sep 18 15:39:39.672: Got socket write event to resend on socket fd 0 resend queue:0x7F721D1FE410
*Sep 18 15:39:39.725: PP: pp_sock_tcp_read_handler sock:0 session:7F7220283A60
*Sep 18 15:39:39.725: PP delete session:0x7F7220283A60, core:0, access:0
*Sep 18 15:39:39.725: Remove device hash table for phone 69.156.48.65 : 49714
*Sep 18 15:39:42.356: Phoneproxy_mgt_process, unknown event.
*Sep 18 15:39:42.375: Phoneproxy_mgt_process, unknown event.
*Sep 18 15:39:42.375: Phone proxy new phone event handler 1
*Sep 18 15:39:42.375: Phone proxy: TCP Socket accept
*Sep 18 15:39:42.375: Create device hash table for phone 69.156.48.65 : 49715
*Sep 18 15:39:42.375: TCP access socket inherit fd:0 from fd:5
*Sep 18 15:39:42.375: pp_add_tcp_access_socket session 0x7F7220283A60 access side raddr:69.156.48.65, socket:0
*Sep 18 15:39:42.376: PP: pp_sock_tcp_read_handler sock:0 session:7F7220283A60
*Sep 18 15:39:42.376: access socket recv http:GET /Canada/g3-tones.xml.sgn HTTP/1.1
*Sep 18 15:39:42.376: PP: Remote phone from 69.156.48.65/49715 requesting GET /Canada/g3-tones.xml.sgn HTTP/1.1
at 209.29.5.21/6970
*Sep 18 15:39:42.377: get file name:Canada/g3-tones.xml.sgn
*Sep 18 15:39:42.377: DBG: check if filename(Canada/g3-tones.xml.sgn) buffered
*Sep 18 15:39:42.377: core side ip 10.26.200.11 session 0x7F7220283A60
*Sep 18 15:39:42.377: PP socket connect 1 remote addr 10.26.200.11 port 6970
*Sep 18 15:39:42.377: PP socket connect 1 remote addr 10.26.200.11 port 6970 in progress
*Sep 18 15:39:42.377: pp_add_tcp_core_socket session 0x7F7220283A60 core side raddr:10.26.200.11, socket:1
*Sep 18 15:39:42.377: PP: SBC sent request for Canada/g3-tones.xml.sgn sourced from 10.26.200.30:40072 to 10.26.200.11:6970, vrf Global
*Sep 18 15:39:42.377: PP: modify http host, header:GET /Canada/g3-tones.xml.sgn HTTP/1.1
, size: 65
*Sep 18 15:39:42.377: Phoneproxy tried to send data 0x7F72202D7340 65 bytes, socket 1 sent nothing,tcp connect not finished
*Sep 18 15:39:42.378: Got socket write event to resend on socket fd 1 resend queue:0x7F721D1FE4F0
*Sep 18 15:39:42.378: PP: pp_sock_tcp_read_handler sock:1 session:7F7220283A60
*Sep 18 15:39:42.380: PP: pp_sock_tcp_read_handler sock:1 session:7F7220283A60
*Sep 18 15:39:42.380: http core side first pkg
*Sep 18 15:39:42.380: http error msg
*Sep 18 15:39:42.380: PP: Data sent from 209.29.5.21/6970 to remote phone at 69.156.48.65/49715
*Sep 18 15:39:42.380: PP delete session:0x7F7220283A60, core:0, access:1
*Sep 18 15:39:42.400: PP: pp_sock_tcp_read_handler sock:0 session:7F7220283A60
*Sep 18 15:39:42.400: PP delete session:0x7F7220283A60, core:0, access:0
*Sep 18 15:39:42.400: Remove device hash table for phone 69.156.48.65 : 49715
*Sep 18 15:39:42.786: Phoneproxy_mgt_process, unknown event.
*Sep 18 15:39:42.804: Phoneproxy_mgt_process, unknown event.
*Sep 18 15:39:42.804: Phone proxy new phone event handler 1
*Sep 18 15:39:42.804: Phone proxy: TCP Socket accept
*Sep 18 15:39:42.805: Create device hash table for phone 69.156.48.65 : 49716
*Sep 18 15:39:42.805: TCP access socket inherit fd:0 from fd:5
*Sep 18 15:39:42.805: pp_add_tcp_access_socket session 0x7F7220283A60 access side raddr:69.156.48.65, socket:0
*Sep 18 15:39:42.805: PP: pp_sock_tcp_read_handler sock:0 session:7F7220283A60
*Sep 18 15:39:42.806: access socket recv http:GET /AppDialRules.xml HTTP/1.1
one more clarification - config was also changed for posting purpose (IP replaces with <device_ip> statements.)
