CUBE SIP profile for Diversion header
VON CLAWSON
Level 3
Level 3
I've got a problem with Diversion headers.  our DN's are configured as +E.164.  When forwarding calls we send out the Diversion header with the number of the phone.  This should work but the number that gets populated is +1XXXXXXXXXX. And the carrier is not accepting that.  It will accept it without the +1.  So I am trying to use SIP profiles to remove the +1 from the Diversion header but it is not working.
Here is the invite:
5047483: Oct 18 11:48:32.649 MDT: //4713576/06089D800000/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:8018197960@165.117.119.158 SIP/2.0
Via: SIP/2.0/UDP 10.225.255.249:5060;branch=z9hG4bK4521622390
From: "WIRELESS CALLER" <sip:4802001918@10.225.255.249>;tag=E2FD44C4-E3E
To: <sip:8018197960@165.117.119.158>
Date: Thu, 18 Oct 2018 17:48:32 GMT
Call-ID: DD39E44A-D23411E8-A37FA40F-83E7177C@10.225.255.249
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 0101227904-0000065536-0000031816-0184869130
User-Agent: Cisco-SIPGateway/IOS-15.4.3.M5
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1539884912
Contact: <sip:4802001918@10.225.255.249:5060>
Expires: 180
Allow-Events: telephone-event
Max-Forwards: 66
P-Preferred-Identity: "WIRELESS CALLER" <sip:4802001918@10.225.255.249>
Diversion: "Kaye Parrish"<sip:+18015634115@10.225.255.249>;privacy=off;reason=unconditional;screen=yes
Session-Expires:  1800
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 349
v=0
o=CiscoSystemsSIP-GW-UserAgent 7233 8884 IN IP4 10.225.255.249
s=SIP Call
c=IN IP4 10.225.255.249
t=0 0
m=audio 16574 RTP/AVP 0 18 100 101
a=rtpmap:0 PCMU/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:100 X-NSE/8000
a=fmtp:100 192-194
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=ptime:20
Note that the Diversion header is there and it is:
Here is my SIP profile
voice class sip-profiles 1001
 request INVITE sip-header Diversion modify "<sip:+1801563(.*)@" "<sip:801563\1@"
and my Dial-peer
dial-peer voice 1001 voip
 description Outbound calls to SIP-801-563-Midvale-UT-01
 translation-profile outgoing ToSIPPSTN
 destination-pattern 801563*T
 session protocol sipv2
 session server-group 20
 voice-class codec 1
 voice-class sip profiles 1001
 voice-class sip options-keepalive profile 20
 dtmf-relay rtp-nte
 no vad
For some reason it does not appear to match the profile that I have setup so it is not changing the Diversion header and removing the +1.
Please rate if this helps.
Evgeny Izetov
I prefer to use a translation rule instead:
voice translation-rule 1
rule 1 /^\+1/ //
voice translation-profile ToPSTN
translate redirect-called 1
Sreekanth Narayanan
You're missing the escape for the '+' sign in the Diversion header number.
This profile should work.
request INVITE sip-header Diversion modify "(.*)<sip:\+1801563(.*)" "\1<sip:801563\2"
FYI, you can also use this tool to test your sip profiles. https://cway.cisco.com/tools/SipProfileTest/
