CUC 10 hostname change
Rajkumar Yadav
Level 4
Level 4
Just wanted to clarify the exact procedure for the hostname change for the CUC.
As for CUCM, Im & Presence the command is set network hostname, however for the CUC the below link does not mention the same.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/10x/install_upgrade/guide/10xcuciumgx.pdf
Please refer page 75,76 where they stating to use for alternate hostname via command set web-security.
I have used the set network hostname in CUC and it worked fine.
Could any one please confirm the exact procedure.
Raaj.
Aditya Gupta
Hi Rajkumar
Please refer the link below for hostname change procedure on cuc
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/9x/upgrade/guide/9xcucrugx/9xcucrug060.html#wp1053641
Aditya Gupta
Aditya Gupta
Hi Rajkumar
Aditya Gupta
Hi Aditya,
This is for CUC 9, however i have followed right procedure.
Raaj.
