CUC 10.X transfere problem
Zaher Juha
Dears,
When someone calls from outside the call will be forwarded to an AA configured on a CUC
The AA will ask to dial the required extension, when the caller dial an extensioned not under a user in the Cisco unity the call will not be transfered
I tried with the restirction table but the same problem
Any idea about this problem
You need to configure your restriction tables to allow calls to non VM enabled users.
You may also need to configure the "allow transfer to non voicemail users" on the greetings page of the Call Handler
Anas
don't forget to rate the helpful posts
9 Replies 9
Anas Abueideh
Level 9
Level 9
by default unity connection allow calls for its contacts (users who have voicemailbox)
to bypass that, you need to do the below:
On the Default System Transfer Restriction Table, when I want to transfer to extensions
for example extensions  begin with 8 but are not part of Unity Connection you need to set;
8???* - Allow
If it was numbers that begin with 5 it would be;
5???* - Allow
Anas
Hi Anas,
Thanks, I tried but still the same problem
what i did, under Restriction Table Basics  Default Transfer and Default system Transfer
i added 45? to transfere the call to extension 451 but no change
also i tried 451 instead of 45? the same, :(
Anas
Thanks Anas
under During Greeting
Allow Transfers to Numbers Not Associated with Users or Call Handlers
Thanks to you it's working :)
Does the CSS for the integration allows you to reach those DNs exactly as you're dialing them in CUC??
java
if this helps, please rate
Thanks Jaime
It's allowed already
try to do the same for Default Transfer in the restriction table.
also make sure you have the appropriate CSS
Anas
Kindly check the Screenshot
the same can't transfere
Hi Anas,
I have the same error it seems that AA cannot connect with my DN in CUCM.
When I tried calling users with voicemail it just going to voicemail, when I tried calling non voice mail user it just saying "cannot be transferred to this number please check your number and try again." I already followed the steps below. Please help.
