version: 11.5.1.11900-26
Section is: Search Call Handlers ->Edit Call Handler Basics (Standard) -> Greetings -> Edit Greeting (Standard)
check the attached image file please.
what is the reason?
Solved! Go to Solution.
Hi Victor,
We have faced similar issue post CUC upgrade to V11 and the work around below worked..
We followed the below procedure & after that, it started showing the Call Action option under Call Handler – Greetings as well as under Caller Input.
- Unity Connection Administration > Go to the System Settings/General Configuration page, verify that it show U.S. English as the default system language.
- If yes, then just press the Save button on that page without changing anything.
Safdar
Please rate useful post.
Hi Victor,
Safdar
You are rigth. TAC told me the same workaround and it fixed my issue.
