08-09-2021 09:05 AM - edited 08-09-2021 09:08 AM
I was trying to Fresh install CUC cluster (version 14) over WAN using PCD 14.
CUC publisher successfully installed but CUC subscriber in other site Host machine failed as below:
CUC version : 14.0
ESXi verion : 7.0
hardware: BE7000M
please help me
Attaching error pic
Im using 15 character long security password with underscore("_"). Is this making an issue?
Im now worried that CUCM cluster will also failed if so
very urgent situation. This was my test installation. but it failed at the end. every thing was going so smoothly.
08-10-2021 03:48 AM
Have you tried the suggestion from @Nithin Eluvathingal to run the installation from the console of the VM in vCenter instead of sticking to PCD, that seems to give you problems?
08-16-2021 03:29 AM
i rebuild again with PCD. This time everything went successfully without any issue. i dont know why there was issue in the first time.
