08-01-2016 10:55 AM - edited 03-17-2019 07:42 AM
I am in need of help with the following please.
CUC active version: 10.5.2.13900-12
inactive partition has: UCSInstall_UCOS_11.0.1.22900-14.sgn.iso
I get the following error when I attenpt to switch versions:
'Only one entry found in /grub/boot/grub/grub.conf. Cannot swap grub entries Failed to Switch Version and Restart the Appliance'
Please help. Customer is expecting the upgrade by tomorrow.
Many thanks, John.
Solved! Go to Solution.
08-01-2016 11:49 AM
Was the upgrade successful?? If a cluster, was it successful on both servers??
If this is a time sensitive matter, and this is a production system, you should be opening a TAC.
08-01-2016 11:49 AM
08-10-2016 03:02 AM
OK. Many thanks. TAC case now open.
