CUCM 10.5.2 Common Partition 97%
Aman .
Disk/active         20304764K        7399656K       12698824K (64%)
Disk/inactive       20304764K        7562028K       12536452K (63%)
Disk/logging        70646184K        2077832K       64979696K (97%
admin:show diskusage common sort
This command can take significantly long time,
and can also effect the system wide IOWAIT on your system.
Continue (y/n)?y
Filesystem     1K-blocks     Used Available Use% Mounted on
/dev/sda6       70646184 64979184   2078344  97% /common
39114836        /common/
38987460        /common/log
20335440        /common/log/taos-log-b
18306180        /common/log/taos-log-a
9476016 /common/log/taos-log-a/car_db
9476016 /common/log/taos-log-b/car_db
6222004 /common/log/taos-log-a/car_db/cardbspace
6222004 /common/log/taos-log-b/car_db/cardbspace
4155216 /common/log/taos-log-b/cm
4080060 /common/log/taos-log-b/syslog
3732984 /common/log/taos-log-a/cm
2945816 /common/log/taos-log-b/cm/tftpdata
2710324 /common/log/taos-log-a/cm/tftpdata
2700780 /common/log/taos-log-a/syslog
2002004 /common/log/taos-log-a/car_db/cartempdbs
2002004 /common/log/taos-log-b/car_db/cartempdbs
1487336 /common/log/taos-log-b/tomcat
1335904 /common/log/taos-log-a/tomcat
1315828 /common/log/taos-log-b/tomcat/webapps
1315372 /common/log/taos-log-a/tomcat/webapps
1098004 /common/log/taos-log-a/car_db/carlogdbs
Deleted Logs from RTMT and CLI.
changed the LogPartitionHighWaterMarkExceeded and LogPartitionLowWaterMarkExceeded threshold values to lower numbers (for example, 30/20).
Purged CAR from System > Database > Manual Purge
What else I should Delete ? ..
9 Replies 9
Deepak Rawat
After changing the log partition, did you restart the below service:
Cisco Log Partition Monitoring Tool service under Serviceability -> Network Services
Deepak
Yupp... 2 times.
Rajan
Hi Aman,
Try using the COP file (ciscocm.free_common_space_v1.1.cop.sgn) to clear some space on the common partition.
Download link for COp file:
https://software.cisco.com/download/release.html?mdfid=285963825&flowid=77896&softwareid=282204704&release=COP-Files&relind=AVAILABLE&rellifecycle=&reltype=latest
Rajan
The cop was available for 9.1 , will it work in 10.5
Deepak Rawat
Be careful in running this cop file because of below reasons:
http://docwiki.cisco.com/wiki/CUCM_Upgrades_and_Migrations_FAQ#What_COP_files_do_I_need.3F.3F
Deepak
Amit Sharawat
Changing the LogPartitionHighWaterMarkExceeded and LogPartitionLowWaterMarkExceeded threshold values to lower numbers (for example, 30/20) should do the trick.
Please make sure that you set them to 95/90 again after sometime to avoid frequent alerts.
As you would have read in the question, it didn't help. Kept it at 20-30 for 3-4 days... The % increased from 96 to 97.
Aman,
You can try the cop file:
But, incase that does not resolve the issue, you need to :
Go to CDR page and change the Configure Automatic Database Purge
Reboot the server.
The system should be stable after that.
Aman .
Let us analyze the below output :
39114836        /common/
I am aware about traces in CM ..and have deleted sdi and sdl traces via CLI as well (although only two files were there, I believe that's because of low & high watermark configuration set to 20-30 right now).
I am not aware of "cardbspace" .. as we can see that is the one occupying most space .. does this give any hints ? I am willing to go into cardbspace and delete some files... but which one ? I am not sure...Does anyone has an idea on this  ? Or, am I looking in wrong direction ?
