CUCM 10.5 or CUCM 11
We are looking for new version of CUCM . Just want to know which is stable version right now CUCM 10.5 or CUCM 11 ? Have anyone faced any major issue with CUCM 10.5 or CUCM 11 ? What are the new feature in CUCM 11 ?
Jaime Valencia
10.5(2) is the MR in the 10.x train, and I've had not seen any major issues with 11 in my lab.
The new features for a release are always listed in the RNs. They also contain the bugs that affect each, you can review them to determine if any of them might affect you.
java
if this helps, please rate
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/rel_notes/11_0_1/CUCM_BK_R30921A8_00_CUCM_release-notes_1101/CUCM_BK_R30921A8_00_release-notes-for-cisco-unified_chapter_00.html
In case if you are looking for the Release Notes for the CCM 11.x
Chris Deren
It really comes down to 2 things:
1. are there features in version .0 that you really need/want
2. are you ok with another upgrade in short future as .0 release have half the life span of .5.
devils_advocate
Level 7
Level 7
We run 10.5 in production and I have a v11 test server.
I wanted to test the new Conference Now features in 11 which seem to work fairly well.
Are you looking to upgrade or build a new server/cluster?
