CUCM 10.5 Remote Destination End User Options Self Care Portal
Tom W.
Can anyone tell us how to enable and then where to navigate to, to find the Remote Destination options on the Self Care Portal of CUCM for End User Options?
Tom
Jaime Valencia
https://youtu.be/IPrzQJGFpec
java
if this helps, please rate
Georgios Fotiadis
You don't have to enable any self-care portal specific parameter. All you have to do is configure the Remote Destination properly and it will appear at "Phones" section on Self-Care Portal.
Georgios
Please rate if you find this helpful.
