CUCM 10.x license re-generation
ShankarP
Hi Experts, we have an requirement to change CUCM/UCX 10 IP address and there seems to be a possibility of current license becoming void.
We have a SmartNet support for Hardware, would like to check if the support covers license re-generation by TAC? or do we need SWSS Support? Thanks
Jaime Valencia
10.x uses PLM and there is no dependency on the IP, that was 8.x and below with the licensing MAC.
java
if this helps, please rate
HARIS_HUSSAIN
Changing CUCM Ip will not impact the cucm licensing in v 10.x and above.
Hi, got below warning for UCCX.
admin:show version active
Active Master Version: 10.5.1.10000-24
Active Version Installed Software Options:
No Installed Software Options Found.
admin:set network ip eth0 192.168.0.21 255.255.255.0 192.168.0.1
WARNING: Changing this setting will invalidate software license
on this server. The license will have to be re-hosted.
Continue(y/n):
Continue (y/n)?n
This is true for UCCX. If you change IP Of UCCX then of course you would need to re host licenses. But for CUCM Not required.
