08-30-2016 12:25 AM - edited 03-17-2019 07:58 AM
Hi all
We updated our CUCM-Clusters last weekend from 11.0.1.21900-14 to 11.0.1.22900-14. After that, we observed that some calls cannot be picked up anymore. If pickup is pressed, the call ends immediately and the caller hears fast busy. We observed it with several phone models (7841, 8851). Resetting, deleting and factory resetting the phones didn't help. We also deleted the pickup-group and configured it new.
Using RTMT, we saw the following error during pickup:
Solved! Go to Solution.
08-30-2016 12:33 AM
Hi Joel,
If only SIP phones are affected by this then it can be the following bug
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCva71953/?reffering_site=dumpcr
You will need an upgrade to the ES for 11.0.1 with the fix.
Manish
08-30-2016 12:33 AM
Hi Joel,
Manish
08-30-2016 02:35 AM
Hi Manish
You're right. We configured the directory uri on the Directory Number configuration page and pickup worked!!
Thanks a lot for your fast response! Great job.
08-30-2016 02:37 AM
Good to know that it worked, thanks for updating the post for the benefit of all.
Manish
08-30-2016 05:50 AM
Hi all
Problem still persists when calling on a hunt pilot, where no direcory uri can be defined...is there another workaround?
08-30-2016 06:02 AM
Hi Joel,
Unfortunately there doesn't seem to be a workaround for the hunt pilot, you may open a TAC case to get the ES for 11.0.1 with a fix or check the release notes of latest 11.5 on cisco.com and see if the bug is fixed in that and upgrade to the same.
Manish
