05-13-2019 07:52 AM
Is there any reason to keep any files in the TFTP (file list tftp *) on a CUCM Publisher, when you have two other dedicated TFTP servers in the cluster.
Facing the free common space issue on a lot of 11.5 upgrades related to the publisher. Running the .cop files helps some but not enough. Adjusting watermarks, purging CDRs, all with 200 phones using a 7500 user nodes with 110GB drive.
I don't see why Cisco can't start using a larger virtual drive, give the Telepresence CE files are GB in size.
05-13-2019 08:14 AM
05-13-2019 10:18 AM
05-13-2019 10:30 AM
Hi there
yes, though CUCM PUB is not being used as any of the TFTP servers, still the files will be available. I don't say its a poor disk management as the fact that CUCM PUBLISHER is handling the DB and can invoke as a TFTP at events of catastrophe. Yes, also the fact that the HD space can be a limitation. The only idea should be cleaning up the TFTP for un-used or old firmwares, MOH, png files etc.
Hope this Helps
Cheers
Rath!
***Please rate helpful posts***
