CUCM 11.5 PUB can not login using CLI
I am facing an issue for login in CUCM PUB OS Admin on CLI, while logging in as I am giving the username and password, it shutdown the putty. I am able to login CUCM PUB OS admin GUI. Able to login CUCM sub using CLI and GUI.
I have CUCM 11.5 version and not able to login using CLI. Can u please help me to resolve this issue.
6 Replies 6
Jaime Valencia
Can you login via console?
java
if this helps, please rate
 CUCM PUB Not able to login using   console , GUI, CLI.
CUCM Version:11.5.1.10000-6
also PLM is not synchronizing
Are you absolutely sure you have the right credentials?
Have you tried resetting the password?
java
Yes I am sure I have correct login details.
I am able to login only administration cucm pub .
Not able to os admin GUI and cli, cucm console.
I have cucm sub and I am using same login details and able to login.
What message do you get when you try with those credentials?
java
Getting Access denied.
I didn't try to reset password.
