CUCM 11 GW h323 Requested circuit/channel not available
cristian.munoz
Level 4
Level 4
Hi All
 I have a problem.
I have a CUCM 11 and H323 PRI E1. For outgoing call, the follow message is show it:
Here a ISDN Q931 debug
Sep  5 14:33:37.771: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x3470
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA9839F
                Exclusive, Channel 31
        Calling Party Number i = 0x0081, '229793200'
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0x80, '226928000'
Sep  5 14:33:37.855: ISDN Se0/0/0:15 Q931: RX <- SETUP_ACK pd = 8  callref = 0xB470
Sep  5 14:33:37.859: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0xB470
        Progress Ind i = 0x8288 - In-band info or appropriate now available
Sep  5 14:33:37.871: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x3470
        Cause i = 0x80AC - Requested circuit/channel not available
Sep  5 14:33:38.047: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8  callref = 0xB470
Sep  5 14:33:38.051: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x347
TIA
Cristian
Rodrigo Garcia
It can be several things but first, make sure the number of channels you have configured in your voice gw matches the number of channels you are purchasing from the Service Provider. If you have more channels in your voice gw than the service provider, eventually the voice gw will try to use a channel that is not in service on the Service Provider's end.
It's a long time since I used it but there's a configuration command to tell the Cisco whether to number B channels contiguously, ie from 1 to 30, or mapped directly to time slots ie 1-15 and 17-31.   The convention needs to match the provider, otherwise any call for channel 16 or above will fair.
The command was "isdn contiguous-bchan" but you will need to check it still applies to your particular IOS.
