05-18-2016 12:30 PM - edited 03-17-2019 06:58 AM
Dears,
I am translating extension 111 after office hrs and weekends by TOD to a GSM number it is working fine for both internal and external users but the problem is I don't want a internal user's calls to be translated to the GSM number I want only external callers call should be translated, Is it possible ???
05-18-2016 12:43 PM
Internal users should have unique calling search space from incoming gateway. Something similar to this:
Gateway
gateway_xlate_css
gateway_xlate_pt
internal_pt
Users
site_css
tod_pt
site_pt
internal_pt
outbound_pt
05-18-2016 12:59 PM
Dear sysjes
Can you elaborate more I didn't understood,
Internal users calls should not be translated to GSM this is my goal so the traffic is going from inside to outside but from your above replies if I am not wrong you are mentioning for the PSTN inbound calls??
05-18-2016 01:03 PM
This all done with CSS and partitions, you just need to adjust your config to do what you want.
05-18-2016 01:06 PM
sorry the tod_pt would belong in the gateway_css instead of the site_css.
05-18-2016 01:37 PM
Hello sysjes
Translation pattern
ext:111
pt : helpdesk_TOD
CSS: GSM_pt
Internal_pt
CSS-Gateway
helpdesk_TOD
Internal_pt
Is it the configuration above correct Pls confirm, I am confused can you write a steps for the extension 111 which is been assigned to Helpdesk_PT, what partition I have to choose in the translation pattern and the translation pattern CSS which partition should not be included.
thanks
05-19-2016 06:56 AM
Yes. That's about it. Change your DN/Xlate partition to helpdesk_TOD and add the helpdesk_TOD to the Gateway CSS. AS long as the gateway css (outside callers) and the internal callers css are different this should work for you.
05-19-2016 10:52 AM
Dear Sysjes,
things are not working to me as expected will put everything below.
extension 111: helpdesk_pt
extension 111: EM_PT
CSS_HELPDESK: GSM,LANDLINE,INTERNAL,EM_PT
Extension 112: internal_PT
extension 112: EM_PT
CSS_Employee: GSM,LANDLINE,HELPDESK_PT ,EM_PT
TRANSLATION PATTERN:
EXTENSION: 111
PARTITION: TRANSLATE-AFTR-4
CSS_TRANSLATE-AFTR-4: GSM,LANDLINE
TRANSLATE TO: 9898989898
CSS-GATEWAY: GSM,LANDLINE,TRANSLATE-AFTR-4,INTERNAL,HELPDESK_PT ,EM_PT
After doing the above configuration when a internal user calls 111 after 4 pm the call is route to GSM number
05-19-2016 11:28 AM
Can you run dial number analyzer on that phone against 111? Take a look at the call flow. That phone should not have access to translate-after-4 partition. Check to make sure there is no other translations or directory numbers that forwards or translates to the external number.
05-19-2016 12:18 PM
To achieve what you are asking:
- Create a time period and a time schedule accordingly with your needs.
- Create a new partition e.g. 111_AfterHours and apply the previously created time schedule.
- Create a separate CSS e.g. From_Gateway and put the previously created partition ate the top of the list and include also other partitions that gateway needs to reach internal extensions.
- Apply that CSS to incoming calling search space on gateway configuration.
- Create a Route pattern 111 , fill the called party transformation mask with the GSM you want to call and put this RP in 111_AfterHours partition
- Do NOT apply the newly create CSS to IP Phones DN
Carlo
