CUCM 12.5 integration with Fanvil
Hello everyone,
Is there a way that I can integrate Cisco CUCM 12.5 with Fanvil call manager and can we integrate IP phones of both companies, assuming Cisco's ip phone will be using 110,111,112 extensions while Fanvil's ip phone will be using 210,211,212 extensions.
Thank you
Jaime Valencia
Assuming the other side can use SIP/H.323 or use a PRI, yes, you should be able to POC this and see what features work.
java
if this helps, please rate
HI,
Please see the below link, I want communication between Cisco CUCM and Fanvil call managers, is it possible to dial extension from 4001 to 5001 and vise versa.
http://prntscr.com/rapst9
Once again, assuming they speak a common protocol, or use TDM to communicate, yes, obviously configure the dial plan on each side to route calls.
java
