CUCM 12.5+ Restart Cisco Smart Licensing Server Service
Hi Pals,
I am working with CUCM 12.5 and I am troubleshooting SSM Satellite communications, I am attempting to restart the Cisco Smart License Server, but the GUI says "No, you can't" and he CLI says "No you can't".
Is there is a way to restart the Smart License Service in Call Manager 12.5+ ?
Thank you very much for your help.
admin:utils service restart Cisco Smart License Manager
Executed command unsuccessfully
Invalid service name for restart, valid names are:
   System SSH
   Cluster Manager
Is there is a way to restart the service in the CUCM Call Manager service?
Or maybe to do this via automation?
But I would prefer to manually restarting for now.
Jaime Valencia
AFAIK you only have two options, either reboot the server, or restart the service via root. Not sure why they don't provide a way to restart that service as the others, might be a good idea for a PER.
java
if this helps, please rate
Jaime Valencia
java
5 Starts, thanks you!
I've restarted the server many times, and the Cisco Smart License Server never starts up successfully.
is actual REBOOT or SHUTDOWN required, instead of just restart ?
