Cucm 12.5 route plan report
When we do search for route plan report in cucm 12.5 it shows fine but when exporting it shows all of the extensions instead of the ones I looked for. The report always is showing all the extensions instead of my search criteria in cucm. I'd this a bug or what's the fix?
Any suggestions
Kaloyan
Hello Horacio,
The documentation doesn't specify whether it should export all results or only the ones that you filtered. I tested this on several different CUCM versions and it always exports the entire route plan report with all of the extensions/patterns. Therefore I can conclude this is working as designed.
john boxold
The Route Plan report export "NumPlan.csv" has always exported the entire report (started downloading in version 5).
