04-11-2023 11:45 AM
Is there a possibility by SQL make a query to remove UDP from specific user, or from user remove UDP that are linked with him?
Kind Regards
04-12-2023 05:59 AM - edited 04-12-2023 05:59 AM
Do this using bulk. Export remove the UDP profile and import the enduser.
With SQL it's doable, but need to make custom query. And if the list of users are huge we need a python script to loop the query.
04-12-2023 10:56 AM
I tried do it but doesn´t work. It´s not possible do it by bulk.
The Bulk Administration Tool (BAT) cannot be used to disassociate devices that are already associated to an end user.
Bulk Administration Guide for Cisco Unified Communications Manager, Release 12.0(1) - User Updates [Cisco Unified Communications Manager Version 12.0]
Bulk Administration Guide for Cisco Unified Communications Manager, Release 12.0(1) -User Updates
04-12-2023 08:58 PM
When I said bulk, I didn't mean the option which you are referring. what I mean is Export the end users, make the change and import the endusers again with override config.
