cucm 12.5 Touchless installation error : Invalid password it is based on a dictionary word.
jaheshkhan
Level 5
Level 5
Today i was trying to install cucm using touchless method. but i entered with the following error:
" Invalid password it is based on a dictionary word.
The password must be at least six characters long and can contain alphanumeric characters, hyphens, and underscores.
The password can not be based on a dictionary word. "
I dont why im gettting this. I tried it with different passwords in AFG file.
Also i tried to generate file using microsoft edge. with mozilla firefox im not getting xml file instead it gives html code.
5 Replies 5
Chris Deren
The error message is pretty self explanatory, it needs to be pretty cryptic and follow all of the guidelines.  This needs to be the case for all 3 passwords: platform, security and application.
Have you considered using PCD for the new install, in my opinion much better option than the toucheless option, especially if you are building a cluster?
I too agree on what you said. but my question
if i gave a password for example, "pass-go0" why its not not accepting.
i have installed before without any issue for version 12.
but with touchless I'm facing this issue..
Chris Deren
I would imagine because ‘pass’ is a dictionary word so it cannot be part of your password.  Change this portion to something like pa$$
"@" no more valid?
"Pa$$@go0" this is not valid too?
I would think that should be fine, perhaps except word ("go"), the only thing I can go by without trying is this section:
Password Recommendations
The installation wizard ensures that you enter a strong password. To create a strong password, follow these recommendations:
  • Mix uppercase and lowercase letters.
  • Mix letters and numbers.
  • Include special symbols.
  • Remember that longer passwords are stronger and more secure than shorter ones.
Avoid the following types of passwords:
  • Do not use recognizable words, such as proper names and dictionary words, even when combined with numbers.
  • Do not invert recognizable words.
  • Do not use word or number patterns, such as aaabbb, qwerty, zyxwvuts, 123321, and so on.
  • Do not use recognizable words from other languages.
  • Do not use personal information of any kind, including birthdays, postal codes, names of children, or pets, and so on.
from the 12.5 install guide:
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/install/12_5_1/cucm_b_install-guide-cucm-imp-1251.pdf
