IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 1183 Views
  • 6 replies
Hello, I am trying to create a hunt group in case calls aren't received by the main receptionist desk.  I've created the Line Group which contains the extensions to receive the call, the hunt list that contains the line group, and the hunt pilot that...
ma_slepko by Beginner
  • 165 Views
  • 1 replies
I am working with a 2811 ISR. The unit is using a single PRI to the PSTN. One small issue is that the customer has only a PVDM16 and therefore not enough DSP's to support the full PRI. I have told them to add another PVDM16. In the mean time I hav...
flash2200 by Beginner
  • 25636 Views
  • 7 replies
i only use my unity for voice mail and AA and have 52 users with voice mail, after syncing my licenses im getting a shortage as shown in the attached picture , does that mean that "Unity Connection Basic Messaging User Licenses" is used for voice mai...
baselzind by Frequent Contributor
  • 346 Views
  • 2 replies
Hi, The CUCM was configured to register with the Jabber Endpoint for phone services. However I see that when I try to login to the application, The Jabber app shows an error saying "Untrusted server. No services discovered." I have the certificates i...
Hello, When logging into CUCM and you are presented with this warning message. Is there any way to monitor for this occurrence? Doesn't appear to be a syslog or RTMT alert. Only if it is in overage for those. I found some OIDs but when I try to walk ...
