10-19-2021 04:09 AM
Hey,
i have weird issue in my environment, when i configure the DNS of the customer i getting error of "WARNING: DNS unreachable"
i check that all the A record and the PTR that configure on the DNS side and its look ok.
after i not found any problem i run diagnose test on the server and i see that i see validate_network problem "Reverse DNS lookup mismatch" , i check again the PTR and its seems ok to me.
i run another test of all the nodes in the dns:
admin:utils network host 10.69.1.3
Local Resolution:
10.69.1.3 resolves locally to DOR-CUCM-SUB1.localdor.com
External Resolution:
3.1.69.10.in-addr.arpa domain name pointer dor-cucm-sub1.
admin:utils network host dor-cucm-sub1
Local Resolution:
dor-cucm-sub1.localdor.com resolves locally to 10.69.1.3 (DOR-CUCM-SUB1.localdor.com)
dor-cucm-sub1.localdor.com has address 10.69.1.3
admin:utils network host 10.69.1.2
Local Resolution:
10.69.1.2 resolves locally to DOR-CUCM-PUB.localdor.com
2.1.69.10.in-addr.arpa domain name pointer dor-cucm-pub.
admin:utils network host dor-cucm-pub.localdor.com
Local Resolution:
dor-cucm-pub.localdor.com resolves locally to 10.69.1.2 (DOR-CUCM-PUB.localdor.com)
dor-cucm-pub.localdor.com has address 10.69.1.2
Local Resolution:
admin:utils network host dor-cucm-sub2.localdor.com
Local Resolution:
dor-cucm-sub2.localdor.com resolves locally to 10.69.5.3 (DOR-CUCM-SUB2.localdor.com)
dor-cucm-sub2.localdor.com has address 10.69.5.3
admin:utils network host 10.69.1.4
Local Resolution:
10.69.1.4 resolves locally to DOR-CUP-PUB.localdor.com
4.1.69.10.in-addr.arpa domain name pointer DOR-CUP-PUB.
admin:utils network host DOR-CUP-PUB.localdor.com
Local Resolution:
DOR-CUP-PUB.localdor.com resolves locally to 10.69.1.4
DOR-CUP-PUB.localdor.com has address 10.69.1.4
admin:utils network host 10.69.5.4
Local Resolution:
10.69.5.4 resolves locally to DOR-CUP-SUB.localdor.com
4.5.69.10.in-addr.arpa domain name pointer DOR-CUP-SUB.
admin:utils network host dor-cup-sub.localdor.com
Local Resolution:
dor-cup-sub.localdor.com resolves locally to 10.69.5.4 (DOR-CUP-SUB.localdor.com)
dor-cup-sub.localdor.com has address 10.69.5.4
its look ok to me i cant see any problem here.
i see that there is bug in cisco "CSCvo01169" that talk about that, i asked from the customer to check about that, but in still want to be sure that it not another problem.
anyone see isuuse like that?
10-19-2021 04:55 AM
is there more than one A record associated with that IP Address? Do they both have PTR records?
If there is, remove the one that does not match the hostname and create a CNAME record instead.
10-21-2021 12:19 AM
Hi Steve,
thank you for your answer.
this is the first think that i check, i saw post about that but im not found any duplicate of A record or PTR.
