CUCM 6.1.1 recovery using recovery disk
Luthfi Anandra
Hi Everyone,
I just recover my CUCM after my CUCM can boot into system.
I have done all the instructions that cisco gave in this url
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080b1f305.shtml
One thing i want to ask after we do the quit command, we remove the recovery disk and reboot the server.
Should we take the CD out from the CD Drive or just keep that CD with recovery .iso inside the CD Drive
And what about the safely reboot, is the system reboot automatically as soon as we quit the recovery disk program or we should hard reboot with pust the power button ?
Thanks for your help
Best Regards,
Luthfi
Terry Cheema
Hi - I had done it few times, and I have already forgotten exactly if reboot was automatic or not :-)
I think once you complete the file sytem repair and press quit - system would allow you to eject the disk and ask you to remove the disk from CD ROM and will shutdown and you will need to power on manually, again I do not remember exactly its been a while since I did this last time. But I can assure you its not complicated and system would keep on generating prompts - you just need to follow that.
Terry
5 Replies 5
Aman Soi
you need to take out the recovery CD from CD Drive after u press Q[Quit] . And u need to press Power button to reboot the server.
This is what I have seen.
regds,
aman
Here you go - you have answer from Aman.
I did not see the reply before I typed from iPhone. +5 to Aman.
Terry
Terry Cheema
Terry
Luthfi Anandra
Hi all,
Thanks for your help and kindness. The problem is solved.
Best Regards,
Luthfi
Good to know your issue is resolved Luthfi. Please mark the thread as answered if you have no more queries.
Terry
