CUCM 6.1.2 BACK UP PROGRESS STUCK
It seems that the back up progreess has stuck
could you pls give any solution for this?
  See atttached files please
Please rate all useful posts Regards Chrysostomos ""The Most Successful People Are Those Who Are Good At Plan B""
clileikis
Level 7
Level 7
Hi there,
Sounds like the following bug:
CSCsr87199
Symptom:
- DRS Backups stop executing automatically.
- When you attempt a manual backup, you get an error saying:
"Backup operation currently in progress.... please wait and try after sometime"
- When trying to install a new version or a COP file, you get the following error:
"The system is currently locked by another process. Please try again later"
Conditions:
Occurs if DRF is scheduled to backup the CUCM server automatically.
Workaround:
Restart the DRF Master Agent on the publisher to be able to install files again.
HTH,
Chris
Please rate helpful posts
clileikis
Level 7
Level 7
Hi there,
CSCsr87199
Symptom:
Conditions:
Workaround:
HTH,
Chris
