12-20-2010 12:26 PM - edited 03-16-2019 02:31 AM
Hi All,
I need to make cucm 6.1.2 clustering over WAN.
i ve 4 servers, two in head office and two in remote site. I need to cluster them over wan to be one cluster contains 4 servers.
what are the prerequisties??
BR,
12-20-2010 12:44 PM
Check SRND
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/6x/uc6_1.html
WAN Considerations
For clustering over the WAN to be successful, you must carefully plan, design, and implement various
characteristics of the WAN itself. The Intra-Cluster Communication Signaling (ICCS) between
Unified CM servers consists of many traffic types. The ICCS traffic types are classified as either priority
or best-effort. Priority ICCS traffic is marked with IP Precedence 3 (DSCP 24 or PHB CS3). Best-effort
ICCS traffic is marked with IP Precedence 0 (DSCP 0 or PHB BE). The various types of ICCS traffic
are described in Intra-Cluster Communications, page 2-20, which also provides further guidelines for
provisioning. The following design guidelines apply to the indicated WAN characteristics:
• Delay
The maximum one-way delay between any two Unified CM 6.0 servers should not exceed 20 msec,
or 40 msec round-trip time (RTT). Beginning with Cisco Unified CM Release 6.1, the maximum
one-way delay between two Unified CM servers can be up to 40 msec, or 80 msec round-trip time.
Measuring the delay is covered in Delay Testing, page 2-21.
• Jitter
Jitter is the varying delay that packets incur through the network due to processing, queue, buffer,
congestion, or path variation delay. Jitter for the IP Precedence 3 ICCS traffic must be minimized
using Quality of Service (QoS) features.
• Packet loss and errors
The network should be engineered to provide sufficient prioritized bandwidth for all ICCS traffic,
especially the priority ICCS traffic. Standard QoS mechanisms must be implemented to avoid
congestion and packet loss. If packets are lost due to line errors or other “real world” conditions, the
ICCS packet will be retransmitted because it uses the TCP protocol for reliable transmission. The
retransmission might result in a call being delayed during setup, disconnect (teardown), or other
supplementary services during the call. Some packet loss conditions could result in a lost call, but
this scenario should be no more likely than errors occurring on a T1 or E1, which affect calls via a
trunk to the PSTN/ISDN.
• Bandwidth
Provision the correct amount of bandwidth between each server for the expected call volume, type
of devices, and number of devices. This bandwidth is in addition to any other bandwidth for other
applications sharing the network, including voice and video traffic between the sites. The bandwidth
provisioned must have QoS enabled to provide the prioritization and scheduling for the different
classes of traffic. The general rule of thumb for bandwidth is to over-provision and under-subscribe.
• Quality of Service
The network infrastructure relies on QoS engineering to provide consistent and predictable
end-to-end levels of service for traffic. Neither QoS nor bandwidth alone is the solution; rather,
QoS-enabled bandwidth must be engineered into the network infrastructure.
12-20-2010 11:20 PM
Hi All,
i appreciate your replies.But actually i know about your replies cause i have read SRND before.
My focal point is:
What about subnets/vlans/IPs over WAN.
In other words Have I to put servers over WAN to be in the same subnet/vlan ?. Waht about IPs for the servers? should CUCM servers in one cluster to join the same cluster over WAN take IPs from the same subnet.
In general, my questions related to low level details.
Appreciate your feed back ASAP.
BR,
12-20-2010 11:54 PM
It depends of your infrastructure.
But it's not a requirement to put all the cluster servers in the same VLAN or same subnet.
You can indeed put all the servers in different IP subnets.
I hope this helps.
Pierre.
12-21-2010 05:22 AM
It is not a problem - even for single site clusters Cisco recommend that CUCM servers be placed into different VLANs/Subnets to avoid DoS or broadcast storm problems.
From the CUCM 6.x SRND
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/6x/netstruc.html#wp1043794
Data Center and Server Farm
Typically, Cisco Unified Communications Manager (Unified CM) cluster servers, including media resource servers, reside in a data center or server farm environment. In addition, centralized gateways and centralized hardware media resources such as conference bridges, DSP or transcoder farms, and media termination points are located in the data center or server farm. Because these servers and resources are critical to voice networks, Cisco recommends distributing all Unified CM cluster servers, centralized voice gateways, and centralized hardware resources between multiple physical switches and, if possible, multiple physical locations within the campus. This distribution of resources ensures that, given a hardware failure (such as a switch or switch line card failure), at least some servers in the cluster will still be available to provide telephony services. In addition, some gateways and hardware resources will still be available to provide access to the PSTN and to provide auxiliary services. Besides being physically distributed, these servers, gateways, and hardware resources should be distributed among separate VLANs or subnets so that, if a broadcast storm or denial of service attack occurs on a particular VLAN, not all voice connectivity and services will be disrupted.
Please rate if helpful.
12-20-2010 12:47 PM
The SRND has full details of clustering over the WAN.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/6x/models.html#wpxref83480
For CUCM 6.1 the maximum one way latency between servers is 40ms.
The key thing you need to work out is your failure strategy. In your scenario I would be tempted to add a third server at the head office and then have a dedicated Publisher with two Subscribers at each site. These would act as primary and secondary CUCM servers for local devices.
Hope this helps - please rate if useful.
