CUCM 7.1.5.32900-2 // dependency records issue
fei he
Level 2
Level 2
I have CUCM  7.1.5.32900-2.
Dependency records return 0 value regardless.
Dependency records is enabled in enterprise parameter.
Any idea?
5 Replies 5
radoslav-drabik
You need to activate the dependency record service. Go to Serviceavailability and look for Service activation.
Rate if it helps.
Sent from Cisco Technical Support Android App
Hi Rado
I dont see "dependency record service" in serviceability page at all through all Pub to Subs, are you referring something else?
Hi Harmit
Thx for your reply, i will see whether restart tomcat helps or not later.
Sounds like a plan Fei! :-)
Harmit.
