02-16-2015 12:57 PM - edited 03-17-2019 02:00 AM
I currently have a destination number set for my call forward no answer external but any call from an external number to the internal network fails to apply the call forward. when i FORWARD ALL to the same destination number the call seems to have established without any dial or ring tone, as if it gets lost.
02-16-2015 01:59 PM
Start by making sure you have properly configured the related CSSs
02-16-2015 09:39 PM
Looks like the CSS is correct as i did what was suggested by Dennis and it worked fine.
02-26-2015 02:18 AM
ok got this working. Added a route pattern that points to call forward partition.
02-16-2015 02:09 PM
Assuming your CSSs are configured with access to the PSTN, please provide your method of access to PSTN (SIP, PRI, FXO, etc) along with relevant gateway logs ie voice ccsip messages
I've seen this before with sip trunk and providers disallowing the call to enter and exit the same gateway, needing to allow sip reinvites
thanks!
02-16-2015 09:45 PM
Hi Jeff
just bear in mind im not a voice engineer. I can provide required information with a little more direction.
02-16-2015 02:27 PM
Assign you extension the CSS that is the same as the call forwarding CSS and see if you can ring the number you are trying to forward to. If you cant dial you have an issue with the Call Forward CSS.
02-16-2015 09:38 PM
Hi Dennis
tried that and the call went though fine.
