04-19-2010 10:17 AM - edited 03-15-2019 10:20 PM
Hi All,
We have just setup a QSIG link between new CUCM 7.1(3) and Nortel Meridian Op.81 using MGCP gateway. The problem we have - there is no caller-name information coming across from CUCM to Meridian. The other way around - Meridian to CUCM - caller name is shown all right. Also we have an old CCM 4.1 connected to the same Meridian using QSIG over MGCP gateway. In the case of calls from this CCM 4.1 to Meridian the name goes across all right. When you trace the call from CCM 4.1 to Meridian you can see a Facility element going across (where I assume the caller name is). But the similar trace for the call between CUCM 7.1 and Meridian does not show any Facility element going from CUCM to Meridian at all. So I wonder if we need to do anything special in CUCM 7.1(3) to enable sending out Caller Name across QSIG link in MGCP configuration.
By the way, if you go to CCM 4.1 MGCP configuration of the link you can see that some tick boxes are ticked there by default: Display IE Delivery, Send Extra Leading Character In DisplayIE, Setup non-ISDN Progress Indicator IE Enable. If you go to the same configuration page in CUCM 7.1 the same settings default to "Disabled", the tick-boxes are not ticked and greyed-out.
Thanks for the help.
Solved! Go to Solution.
04-19-2010 10:37 AM
Hi Alexander,
You may be seeing this bug;
CSCtc68166 Bug Details | Bug #16 of 31 | < Previous | Next > |
ASN.1 ROSE OID Encoding and Calling Name in setup msg using PRI QSIG. | |
Symptom: Outbound calls over QSIG gateway fail or supplementary services like calling name, connected name, callback etc.. fail Conditions: CUCM 7.X and higher QSIG configuration : Serviceparameter - QSIG variant = ECMA Serviceparameter - ASN.1 ROSE OID Encoding = ECMA (GLOBAL) Gateway - QSIG Variant = No Changes Gateway - ASN.1 ROSE OID Encoding = No Changes Workaround: Configure on gateway Gateway - QSIG Variant = ECMA Gateway - ASN.1 ROSE OID Encoding = ECMA (GLOBAL) Further Problem Description: With the configuration documented under conditions, CUCM will encode the Facility/Rose Invoke as ECMA / Local while it is expected to be ECMA / Global. (as configured on the remote PBX) Depending on the remote PBX configuration/type the call will get released or Rose Invoke will get rejected. | Status Fixed Severity 3 - moderate Last Modified In Last Year Product Cisco Unified Communications Manager (CallManager) Technology 1st Found-In 8.0(0.99091.11) Fixed-In 8.0(0.98000.68) 7.1(3.21900.2) 7.1(2.32020.1) 7.1(3.21005.1) 7.1(4.98000.60) 8.0(1.10000.40) |
Cheers!
Rob
Please support CSC Helps Haiti
04-19-2010 10:37 AM
Hi Alexander,
Cheers!
Rob
04-20-2010 03:10 AM
Hi Rob,
Thanks a lot for the answer! I have done the setings as recommended in this article but unfortunately it still does not work. Below is an ISDN Q.931 trace from the gateway for the call:
Apr 20 09:59:27.431: ISDN Se1/0:15 Q931: TX -> SETUP pd = 8 callref = 0x0018
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA9839F
Exclusive, Channel 31
Calling Party Number i = 0x0081, '8999'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '4155'
Apr 20 09:59:27.591: ISDN Se1/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0x8018
Apr 20 09:59:27.595: ISDN Se1/0:15 Q931: RX <- ALERTING pd = 8 callref = 0x8018
Facility i = 0x9FAA068001008201008B0100A10C020201000201018003424F42
Progress Ind i = 0x8182 - Destination address is non-ISDN
Apr 20 09:59:36.895: ISDN Se1/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x0018
Cause i = 0x8190 - Normal call clearing
Apr 20 09:59:36.955: ISDN Se1/0:15 Q931: RX <- RELEASE pd = 8 callref = 0x8018
Apr 20 09:59:36.975: ISDN Se1/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x
0018
The calling extension in CUCM is 8999, the called extension in Meridian is 4155. There is no Calling Name passed from CUCM to Meridian (as you can see there is no Facility element going from CUCM) but there is Called Name passed from Meridian to CUCM (the only Facility element in the trace is the one sent back by Meridian). The version of CUCM I am using is 7.1.3.30000-1.
Alex.
04-22-2010 05:34 AM
Hi Rob,
I have upgraded my CUCM to 7.1(5) and it is all working fine now. Thanks for your help with this.
Cheers,
Alex.
04-22-2010 06:10 AM
Hi Alex,
Nice work my friend
Glad to be of some small help here.
Cheers!
Rob
