02-29-2016 01:08 PM - edited 03-17-2019 06:04 AM
I have CUCM 7.1 Synchronized with LDAP, Suddenly about 30 user of total 750 become deleted(pending) state I don`t know why?.are these users completely deleted from call manager database? and how to fix this problem and get the users back?
Thanks & Regards
Essam
02-29-2016 01:41 PM
That means the users were not found in the last sync, that means they were deleted/moved/etc from LDAP, the SRND discusses the garbage disposal mechanism for LDAP, and explains at which point in time, they will be permanently deleted. Unless you fix whatever you changed in LDAP to cause them to become inactive before that.
03-01-2016 01:24 PM
Find the below link helpful
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/srnd/8x/uc8x/directry.html
After the synchronization is completed, any accounts that were not set to active are permanently deleted from Unified CM when the garbage collection process runs. Garbage collection is a process that runs automatically at the fixed time of 3:15 AM, and it is not configurable. The deletion of Unified CM accounts that do not match LDAP directory accounts is necessary because Unified CM cannot manage accounts while synchronization is configured.
Abhay Reyal
03-01-2016 01:31 PM
Since you are syncing users with the LDAP, please check your LDAP directory (AD). There can be many possibilities:
1.If the users have been deleted from the LDAP Server.
2. If users were moved to a different OU.
VJ
