07-27-2011 07:16 AM - edited 03-16-2019 06:09 AM
Hello everyone,
I have question about PAB.
My client use PAB service as main Directory on CUCM 7 and phone 7942 but what they want is to have Caller Name presented when they receive call from some number which they are added to PAB.
For example:
I have add my mobile phone number, first and last name in PAB and when I calling my office phone from my mobile phone I only see mobile phone number on IP phone display.
Is it possible to display my name on IP phone dispaly together with phone number?
Best regards,
Armin
07-27-2011 08:17 AM
No, CUCM doesn't provide such feature of you adding phones to your PAB and then when you get a call pull the info from PAB and display it.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
07-28-2011 08:04 AM
Hi java,
I assumed that this option is not supported by CUCM but I wanted to hear another opinion from someone who has maybe tried to do the same thing.
Thanks for the helpful information.
Greetings,
Armin
07-27-2011 08:31 AM
Amit,
You will need to use a 3rd party solution, such as 2Ring IPPS (IP Phone Services) - www.2Ring.com\IPPS. Have a look at personal directories and caller identification...
Please contact me if you have any further questions on this - or if you would like to try it in your lab.
Michal
07-28-2011 08:08 AM
Hello Michal,
I will present this solution to my client. If they show interest for is I will contact You.
Thank You.
BR,
Armin
