02-21-2012 08:07 PM - edited 03-16-2019 09:42 AM
Hi all,
Got a weird one here, we're running third party sip phones on cucm cluster
System version: 8.0.3.20000-2
Randomly sip phones are losing registration if the phone is restarted it will re-register.
Phones sip timers are set to 300 seconds timeout and 60 seconds keep alive.
Sip profile is set to 3600 seconds (default keepalive) and 5 seconds for the delta timer (5 seconds before 3600 expires)
Just wondering if anyone can help with regards to what logs in RTMT would help diagnose this issue.
Thanks again
02-21-2012 08:16 PM
collect the call manager logs from RTMT
also collect the packet capture from call manager from the below command
Utils network capture file < file name> size all count 1000000
you can collect these packet capture from RTMT as well!!
thanks
Vipul Jindal
02-21-2012 08:22 PM
What third party SIp phone you are using.. Some third party sip phones use the same Call-ID insted of unique Call-ID and hence issue happens.
Ronak patel
02-21-2012 08:31 PM
Hi Ronak,
We're using a vax voip sip client, it has a proxy server that pushes cucm ip to phone.
Phones are registering with their digest user and password.
All phones will register just over a period of time they will start to unregister.
