CUCM 8.5.1 rejects the SSL 8443 port after SU2 upgrade
rogelioalvez
Hi everybody:
I upgraded my (formerly working) VMware ESXi-based CUCM to SU2 (8.5.1.12900-7 package) on both the Publisher and the Subscriber.
After this upgrade, the Publisher answers with a TCP RST to my connection attempt when the first web page redirects me to the SSL 8443 port. As far as I understand, this is the typical TCP answer from a machine that is not running a service on the requested tcp port.
¿Has anyone ran into this problem? I would reinstall the entire Publisher from the scratch, but the installation and the upgrade process will take 4 hours...
I would appreciate any hints to debug. It seems to be that the SSL engine is not running on my Publisher, but I do not know how to verify if a related process is running or not.
Regards, Rogelio
Joseph Martini
You can try and run "utils diagnose test Cisco Tomcat" (I think that's the correct syntax, you might want to double check).  Can yo connect from a subscriber to the publisher, go to serviceability on the subscriber and try and view the services on the publisher.  If you get a certificate error you likely have a certificate problem for the web service (tomcat).  From the command line you can regenerate it using "set cert regen Cisco Tomcat" (again I might be off a little with the syntax).  Then restart tomcat "utils service restart Cisco Tomcat" to see if that helps.
michael-luo
It sounds like the Tomcat certificate was corrupted.  You may try to get the Tomcat logs from CLI.  Open a TAC case if you don't know how to do that.
Michael
Thank you Michael!. I will read a little and manage to get the logs before trying with TAC. Best regards, Rogelio
Joseph Martini
rogelioalvez
Hi Joe:
Actually, yesterday I tried to restart Tomcat ("utils service restart Cisco Tomcat"), and the process was endlessly trying to restart, so I figured out that the problem was in this process. I did not know how to regenerate the certificate, though. I will give it a shot and let you know.
¿Why should it have failed this way if nothing happened with the Subscriber? In fact, I do not remember any error message upon doing the update. Same update DVD, same virtual machine parameters... I can not understand it.
I will let you know soon!
regards, Rogelio
