CUCM 8.5 H323 C2951 VG202 unable to fax long distance
Jason Hendrix
I have a site is not able to fax long distance. They can receiver all inbound faxes & fax to only local numbers. Site is H323, C2951, VG202, calls go out CO lines, CUCM 8.5. Any suggestions or help would be a GREAT HELP & I will sing your Viking songs for generations!
VG202
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 nse ls-redundancy 0 hs-redundancy 0 fallback cisco
h323
modem passthrough nse codec g711ulaw
voice-port 0/0
input gain 8
timeouts initial 60
timeouts interdigit 60
timeouts ringing infinity
description FAX Hatchery x358
caller-id enable
C2951
voice service voip
fax protocol t38 nse version 0 ls-redundancy 0 hs-redundancy 0 fallback none
h323
voice-port 1/0/18
translation-profile incoming filter_91
signal groundStart
input gain 8
output attenuation 7
no vad
no comfort-noise
timeouts call-disconnect 5
timeouts wait-release 5
connection plar opx 5557777198
description Terminal Line ATT Repair 866-382-0128 ask for Tester
caller-id enable
5 Replies 5
Chris Deren
Can you post your dial peer configuration on both devices?
Is Vg202 pointing to CUCM or the PSTN GW?
Can you provide debugs?
Thanks for the help!
VG202
dial-peer voice 999000 pots
service stcapp
port 0/0
C2951
dial-peer voice 11 voip
preference 1
destination-pattern 87077771..
session target ipv4:10.6.200.152
voice-class h323 1
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
dial-peer voice 220 pots
description Outbound 9T calls
destination-pattern 9T
port 1/0/18
OK, so the VG202 is defined as SCCP, does the device/DN in CUCM have appropriate CSS to allow LD calls?
Is the call actaully going out but you are going error, i.e. line error, or can you not dial out from this line to LD? Is there a handset on the fax that you can use and tell us what you hear when you dial LD number?
Chris
Yes - the device/DN in CUCM have appropriate CSS to allow LD calls. The location can call LD from IP phones & analog phones.
I see the call going out the CO line with "show voice call status". The HP 3035xs MFP dials and you hear ringing but the call just drops after 10 to 20 seconds. You cannot or do not hear a fax tone connecting to the other fax machine. The fax prints "failed to connect".
Just found out there is another fax (same fax) that can fax LD. The site that is failing maybe fax wrong. Site has LD codes... I will et you know unless you have a fix or suggestion.
Thanks!!!
Fixed, case closed -  site was faxing wrong. Site has long distance sode and was not faxing long distance the correct way. Thanks for the help.
HIT FAX BUTTON ON SCREEN.
HIT SCREEN WHERE IT SAYS FAX RECIPIENTS.
THEN TYPE NO.
AND ON THAT SCREEN THERE IS A PAUSE BUTTON AND AN OK BUTTON AND THE SEND BUTTON IS THE GREEN BUTTON ON THE FAX MACHINE ITSELF.
I PUT 9-1-AREA CODE AND NO. , HIT PAUSE BUTTON 3 TIMES AND THEN MY 5 DIGIT CODE AND OK, THEN SEND.
I HOPE THAT MAY HELP.  WHEN YOU HIT PAUSE BUTTON 3 COMMAS WILL SHOW.
