CUCM 8.5 to Shoretel Integration for call routing via 2921 MGCP gateway
sbhavikj
I have a requirement for Shoretel integration with CUCM for call routing. I configured the T1-PRI-QSIG between 2921 MGCP gateway and a Shoretel and the PRI is up. When the calls are placed, I see the call on the gateway but then immediately see a disconnect from router with cause 0x80AF - Resource Unavailable, Unspecified. IOS version is 15.0.1.M3. The DSP's (PVDM3) show no errors.The calls are G.711.
When the call is received on PRI from a Shoretel phone, I am seeing a different message "recovery on timer expiry". This is consistent. Am I missing something?
Any help/pointers greatly appreciated.
Thanks.
5 Replies 5
Chris Deren
Which side is configured as Network?
Have you rebooted the GW?
If you search for these error messages on this forum or google you will find quite a few good links. Have you tried it?
Chris
Thanks for your reply, Chris.
I tried reboot of the router to no avail. The router is configured for Network and I verified that the T1 is clean with no errors. According to Cisco, this error is a temporary failure but in my case it is consistently failing.
Some online posts suggest DSP related issue so I have requested customer to upgrade the IOS to try.
Bhavik Shah
What ISDN switch-type are you using? Is it the same on both sides?
Chris
It is primary-qsig with variant ISO. Shoretel person confirmed this.
The QSIG PRI is working now after converting the gateway to H.323. I suspect that the latency was causing the dropped calls as with MGCP, the latency between GW and CUCM was around 150 msec roundtrip.
Thanks for help.
