How can you tell if a CUCM cluster is using a restricted or unrestricted upgrade of CUCM?
I looked under OS Administration -> Show -> Software and OS Administration -> Settings -> version and did not see any reference to either type.
Cheers
If you don't see the word "unrestricted" after the version on CCMAdmin or OS Admin page when you login you're running the restricted version which is the "normal" version with all security features available to be enabled.
Thanks - you've just answered my question but for CUCM 11.0(1a) SU1 which we are looking to upgrade to 11.5(1)SU2.
Cheers
Rich
