cucm 8.6.1a: SAF learned pattern issue
Ayodeji Okanlawon
Guys,
I have been stuck on a problem since last week. Here is the scenario
1. 3 cucm clusters
2. 1 saf forwarder.
3. 1 cucme (internal client to saf forwarder)
I have configured my cucm as external client and they have all registered to the saf forwarder
I have also configured my cucme and its registered as an interenal client to the saf forwarder
When I do a show voice saf dndb all.. I see all the patterns configured on my cucm clusters.
however when I check on RTMT for the learned patterns, all  I see is the cucme pattern. None of the 3 cucm seem to have picked up any of the advertised pattern from the other cucm.
I was runnign ios 15.1.4M3, due to this issue i changed to 15.1.3T3 and the issue still exist.
Can any one please advise..quite frustrating to  be feeling stucked
Please rate all useful posts
Ayodeji Okanlawon
any thoughts guys?
Hello Ayodeji,
Did you ever figure this out? My learn patterns are showing in RTMT either. Running 8.6.2 CUCM/ 15.1 IOS.
HQ-CORP-2#sh voice saf dndb all
Total no. of patterns in db/max allowed            : 4/6000
Patterns classified under dialplans (private/global) : 4/0
Informational/Error stats -
  Patterns w/ invalid expr detected while add    : 0
  Patterns duplicated under the same instance    : 0
  Patterns rejected overall due to max capacity  : 0
  Attempts to delete a pattern which is invalid  : 2
Last successful DB update @  2014:10:02 00:08:28:450
   ******** Private Dialplan Partition ********
Pattern - 85212XXX
  Primary Trunk-Route(s) ID       : 7
  Alias-Route(s) Prefix/Strip-Len : +55521555/4
Pattern - 85112XXX
  Primary Trunk-Route(s) ID       : 8 10
  Alias-Route(s) Prefix/Strip-Len : +55511555/4
Pattern - 85223XXX
  Alias-Route(s) Prefix/Strip-Len : +66522555/4
Pattern - 85123XXX
  Alias-Route(s) Prefix/Strip-Len : +66512555/4
   ******** Global (E164) Dialplan Partition ********
 - none -
HQ-CORP-2#
I meant "are not displaying in RTMT". My bad
I am sorry I cant remember how I fixed this issue. Its was 3 years ago!
