CUCM 8.6.2 - Error BAT update
wilsonsant
Level 6
Level 6
Hi Guys,
I created in my lab, a one template to include the specific details (specific parameters: DN, Alerting Name, Display, etc...). Now I am trying create the same parameters, but, with another values and when try to do update appear the error message:
Error occurred while retrieving information from database. java.sql.SQLException: A syntax error has occurred.
Any have idea about this?
Wilson
Rob Huffman
Hi Wilson;
It could be this bug;
CSCub67519 Bug DetailsBug #4 of 43 | < Previous | Next >
CUCM 8.6.2.22900-9 BULK update of Phones triggers java exception error.
Symptom:
When updating phones with bulk, the phone configuration options page doesn't load and the following error appear
"Error occurred while retrieving information from database. java.sql.SQLException: A syntax error has occurred."
Conditions:
CUCM version 8.6.2.22900-9
Cisco Unified CM Administration page > Bulk Administration > Phones > Update phones >Query
Find (doesn't matter what filter you use, or even if you left it empty)
- the phone list page appear and right after clicking next (to Choose the phones you want to edit)
- the phone configuration options page doesn't load and the following error appear
Workaround:
Add  a working filter (e.g. Description - null value) with the affected  filter like 'Device Name' which lets us search by Device Name, CSS, etc.  bypassing the error.
This was introduced in ES 8.6.2.22039.1 due to CSCtx96255
You can also revert back to CUCM ES versions prior to 8.6.2.22039.1 or SU1.
Status Status
Fixed
Severity Severity
2 - severe
Last Modified Last Modified
In Last 2 weeks
Product Product
Cisco Unified Communications Manager (CallManager)
Technology Technology
1st Found-In 1st Found-in
8.6(0)
8.6(2.22900.9)
Fixed-In Fixed-in
9.0(1.98000.204)
8.6(2.23047.1)
9.0(1.98000.48)
9.0(1.11004.1)
1.0(0.98000.16)
1.0(0.98000.42)
9.1(1.10000.11)
8.6(2.23900.10)
Cheers!
Rob
"I don't know how, I don't know when
But you and I will meet again "
- Tom Petty
5 Replies 5
Rob Huffman
Hi Wilson,
A couple of questions
What is the exact CUCM version?
Does this happen at this point?
Cheers!
Rob
- Tom Petty
Hi Rob,
The Callmanager is in the  version 8.6.2. The error message is: Error occurred while retrieving information from database. java.sql.SQLException: A syntax error has occurred
Wilson
Rob Huffman
Hi Wilson;
Symptom:
Conditions:
Workaround:
Status Status
Fixed
Severity Severity
2 - severe
In Last 2 weeks
Product Product
8.6(0)
8.6(2.22900.9)
Fixed-In Fixed-in
9.0(1.98000.204)
8.6(2.23047.1)
9.0(1.98000.48)
9.0(1.11004.1)
1.0(0.98000.16)
1.0(0.98000.42)
9.1(1.10000.11)
8.6(2.23900.10)
Cheers!
Rob
- Tom Petty
I think Rob nailed it (as usual).  We ran into this and loaded SU3 and it seemed to do the trick!
Hi Rob,
Thansk a lot. I will apply the release 8.6.2 SU3
Wilson
