CUCM 8.6.2a on UCS C200 M2 - UPS graceful shutdown
angeliquedevos
We have a CUCM 8.6.2a running on a UCS C200 M2. We recently connected a UPS to the UCS blade and I have read in the CUCM release notes that there is a feature that will gracefully shutdown the CUCM when low power is reached. But, I'm wondering how you activate it? The document only mentions about connecting a USB but since this is a virtual server should I make some configuration change to the ESXi?
Here is the link  I'm refering to:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/rel_notes/8_6_2/cucm-rel_notes-862a.html#pgfId-2041345
Thanks!
Angelique
yahsiel2004
Level 7
Level 7
I don't think you can achieve this, when you're running a virtualized CUCM.
Yosh
HTH Regards, Yosh
James Hawkins
Level 8
Level 8
Some UPS providers such as APC have software that works with VMware ESXi and can down hosted virtual machines.
http://www.apc.com/products/resource/include/techspec_index.cfm?base_sku=SFPCNS31-V
I have not tried setting this up but it should work as long as the VMware tools are up to date on the Cisco UC VMs.
