10-15-2015 09:23 PM - edited 03-17-2019 04:35 AM
I want to use a softkey as a speed dial to their help desk. has anyone used the Softkey and not a button to do this. if so how?
Yangfeibo
10-15-2015 09:56 PM
AFAIK, speed dial can't be configured as softkey.
- Vivek
10-15-2015 11:59 PM
Well... as softkey you can configure Abbreviated dial feature.
Carlo
10-16-2015 06:22 AM
Go to the softkey template config, the options you see, are the options you get, nothing else.
The answer is that what you're asking is not possible.
