10-01-2013 01:36 AM - edited 03-16-2019 07:37 PM
We have cucm 8.6 with sip trunk to ISP. We use Cisco ATA 187 and fax machines to send/receive faxes. We have about 4-5 faxes.
We need solution to send/receive faxes via email.
Do you know easy way to do it?
10-01-2013 02:26 AM
Hi Lasha.
From Imagicle Stone fax is a good IP Fax Server.
Otherwise you can go with free customized solutions such as asterisk which can act as IP fax server.
Carlo
Please rate all helpful posts
"The more you help the more you learn"
10-01-2013 04:36 AM
Thanks for reply Carlo
Can you tell me details about asterisk fax server? How can I use asterisk fax with cucm?
10-01-2013 05:02 AM
Hi Lasha.
You can refer to the following link to have an idea on how it works.
http://www.voip-info.org/wiki/view/Asterisk+fax
You can integrate it through a sip trunk making specific route patterns pointing to it.
Carlo
07-03-2014 12:34 AM
also, try to take a look at 2Ring's solution called BUSINESS FAX.
T.38/G.711 protocols are obviously supported.
Get more at http://www.2ring.com/netfax
Martin
