CUCM 8.6 GUI mismatches...
luis.cabrera
Hi all, I have the following problem with CUCM 8.6.2.22900-9, in CUCM Administration GUI under "Devices">>"Gateways", when I make a search, for example, all gateways that content 10., I can see all the gateways, but in the last column the IP Address appears as Unknown, now when I make the same search for 10.3, I can see the same gateways with the IP Address in the last column as I hope to see. All the gateways are working fine.
This happen with whatever browser I use. I attached the screen shots. Any Ideas? Thanks to all for respond.
luis.cabrera
Ready... This happen when you are added gateways with an space after the last digit of the ip address, for some reason this affect to the entire list of the gateways...
Thanks for watch.
Chris Deren
Definitely a bug, you could try to search bug toolkit of open a TAC case, but since this is only esthetic, not sure what they will do.
HTH,
Chris
Thanks for response Chris, agree with you, probably a bug with the GUI...
Regards.
