12-14-2012 05:45 PM - edited 03-16-2019 02:44 PM
Hi everybody.
When I install cucm 8.6, my machine running redhat linux boots and I get the following prompt:
CISCO UNIFIED COMMUNICATION MANAGER 8.6.
LOGIN:
After I entered login and password, I got the screen:
Welcome to command line interface
admin:
I was expecting there would be a wizard asking me ip address for cucm, ntp server's ip etc.
How can i get to that wizard so after I enter all the information , I can use GUI to configure my phones.
Any guidance will be greatly appreciated.
thanks and have a great weekend.
Solved! Go to Solution.
12-14-2012 05:51 PM
Hi Sarah,
It appears you have a server with an existing installation of CUCM. If you boot from the install media you will be able to set all of your CUCM system settings.
You also may have selected "Skip" when it asked you to enter your system settings during the install.
HTH,
Chris
12-14-2012 05:51 PM
Hi Sarah,
HTH,
Chris
