CUCM 9.1.2 Not starting services
Hi, I have a CUCM 9.1.2 Publisher server who doesn't permit phones register. I tried the recovery disk and after that, the server show the attached message when start and the services seem to be starting but always say "starting" and the GUI becomes inaccessible.
Any ideas?
login as: *******
Administrator@10.3.1.31's password:********
Command Line Interface is starting up, please wait ...
java.io.FileNotFoundException: /var/log/active/platform/log/cli.bin (Permission        denied)
        at java.io.RandomAccessFile.open(Native Method)
        at java.io.RandomAccessFile.<init>(RandomAccessFile.java:216)
        at com.cisco.iptplatform.fappend.ciscoRollingFileAppender.restoreIndex(c        iscoRollingFileAppender.java:104)
        at com.cisco.iptplatform.fappend.ciscoRollingFileAppender.setFile(ciscoR        ollingFileAppender.java:43)
        at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
        at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.        java:39)
        at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAcces        sorImpl.java:25)
        at java.lang.reflect.Method.invoke(Method.java:597)
        at org.apache.log4j.config.PropertySetter.setProperty(PropertySetter.jav        a:245)
        at org.apache.log4j.config.PropertySetter.setProperty(PropertySetter.jav        a:204)
        at org.apache.log4j.xml.DOMConfigurator.setParameter(DOMConfigurator.jav        a:691)
        at org.apache.log4j.xml.DOMConfigurator.parseAppender(DOMConfigurator.ja        va:265)
        at org.apache.log4j.xml.DOMConfigurator.findAppenderByName(DOMConfigurat        or.java:176)
        at org.apache.log4j.xml.DOMConfigurator.findAppenderByReference(DOMConfi        gurator.java:191)
        at org.apache.log4j.xml.DOMConfigurator.parseChildrenOfLoggerElement(DOM        Configurator.java:523)
        at org.apache.log4j.xml.DOMConfigurator.parseRoot(DOMConfigurator.java:4        92)
        at org.apache.log4j.xml.DOMConfigurator.parse(DOMConfigurator.java:1001)
        at org.apache.log4j.xml.DOMConfigurator.doConfigure(DOMConfigurator.java        :867)
        at org.apache.log4j.xml.DOMConfigurator.doConfigure(DOMConfigurator.java        :755)
        at org.apache.log4j.xml.DOMConfigurator.configure(DOMConfigurator.java:8        91)
        at sdMain.initialize(sdMain.java:500)
        at sdMain.main(sdMain.java:667)
java.lang.NullPointerException
        at com.cisco.iptplatform.fappend.ciscoRollingFileAppender.updateIndex(ci        scoRollingFileAppender.java:117)
        at com.cisco.iptplatform.fappend.ciscoRollingFileAppender.nextFileName(c        iscoRollingFileAppender.java:92)
        at com.cisco.iptplatform.fappend.ciscoRollingFileAppender.append(ciscoRo        llingFileAppender.java:74)
        at org.apache.log4j.AppenderSkeleton.doAppend(AppenderSkeleton.java:251)
        at org.apache.log4j.helpers.AppenderAttachableImpl.appendLoopOnAppenders        (AppenderAttachableImpl.java:66)
        at org.apache.log4j.Category.callAppenders(Category.java:206)
        at org.apache.log4j.Category.forcedLog(Category.java:391)
        at org.apache.log4j.Category.debug(Category.java:260)
        at com.cisco.iptplatform.cli.CliSettings.getInstance(CliSettings.java:11        4)
        at sdMain.initialize(sdMain.java:512)
log4j:ERROR No output stream or file set for the appender named [CLI_LOG].
   Welcome to the Platform Command Line Interface
admin:
Jaime Valencia
If you already had to run the recovery disk (for whatever problems you already had) and services are not coming up, you probably want to either open a TAC, or start rebuilding the server.
java
if this helps, please rate
