CUCM 9.1 DIAL NUMBER
vitali555md
Hi.could you help me, please. I have a number +XXX (XX) XXXXXX and when I dial this number, I can't call. Answer to me please: if it is possible this setting and if it is possible, where I can find it: in CUBE or CUCM??? PLEAS!!!!!!!
14 Replies 14
Jaime Valencia
Inbound???
Outbound call??
Call flow??
java
if this helps, please rate
outbound call
If you don't provide enough details and the exact behavior you're seeing, theres no way you'll get an answer.
java
Hi.
Please give a look to this doc.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/9_1_1/ccmsys/CUCM_BK_C5565591_00_cucm-system-guide-91_chapter_010000.html#CUCM_RF_UAD8BE59_00
Carlo
Please rate all helpful posts "The more you help the more you learn"
I set on route pattern \+!# and at \+.0!# but is doesn't work.
Hi.
You can try
discard digits pre dot
prefix outgoing 00
Carlo
thanks for answer, but it do not work. "your call cannot be completed as dialed please consult your directory ..."
Hi.
What signaling protocol have you configure to reach your voice gateway? (MGCP/H323/SIP)
Check also the partition you have configured the suggested Route Pattern.
Let me know
Carlo
voice gateway SIP;
Hi.
Can please post a show run of your VG and a debug voice dialpeer inout during a call to an E.164 number?
Carlo
no i don't
In this case we can't help you.
Carlo
thanks for help
It appears you are requiring the # character at the end of the phone  number, and also sending that to the telco. (I cannot see the entire  route pattern or translation pattern in your post.)
Try sending the number without the #
D
