CUCM 9.1 last login message error
saurabh_om
i am coming across an issue wehre AD user try to login CUCM admin and sees incorrect last logiin message. It shows last login from 1 Jan 1970. But if ccmadmin login it shows correct date and time for last login.
attached are screenshots.   Not sure is CUCM restart will work here.
Saurabh
Thanks Saurabh
Manish Gogna
Hi Saurabh,
You are affected by the following
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCue02482
Symptom:
When logging in to Cisco Unified CM Administration Webpage:
GUI displays:
Last Successful Logon: Wednesday, December 31, 1969 7:00:00 PM EST
Date/Time does not change even after additional updates.
Conditions:
* Observed in CUCM  9.0.1.10000-37 and CUCM 9.1.1.10000-11
* LDAP authentication enabled
It is not fixed yet, so you need to wait for the fix.
Manish
