05-09-2016 08:42 PM - edited 03-17-2019 06:50 AM
Hi there, our campus is requiring an inventory of phones. possible to glance at what models, serial numbers and totals of phones in real time monitoring tool?
cheers,
matt
05-09-2016 09:01 PM
You should be able to get phone model and count from cisco unified reporting - cluster device summary report.
I am not too sure if there is any way of exporting serial numbers. Thanks
05-09-2016 10:30 PM
You can also try running below from CM CLI:
run sql select name,description,tkmodel from device where name like 'SEP%'
In order to match the phone model against the tkmodel which you get in the output of above command, simply run below command
run sql select name,tkmodel from TypeProduct
After you get the required outputs from above commands, simply put them in excel and get the total count. You can also change the query directly to get the count as well however Excel is pretty good to do all these kind of things in my opinion
run sql select count(name) from device where name like 'SEP%'
Deepak
05-09-2016 11:03 PM
If you want SN of the devices, you need to look at 3rd party options to get that information
